The PG Classics wheel is decent looking. They need to address a couple issues with them though.
1. The horn switch mounting holes are threaded metric. Trying to retap the holes to reuse the stock mounting screws isn't easy.
2. The polishing job on the spokes is pretty lame. Lots of sanding scratches. I ended up sanding the spokes on mine so they looked uniform...instead of trying to finish the polishing job. I didn't want to damage the leather grip by trying to polish right up to the edge.
As far as the "can"(Tuff Wheel adapter) is concerned...
If you are looking for an original adapter, make sure the internal splines have a "master spline". The trucks used an almost identical adapter but those don't have a master spline. The truck adapter won't fit over the steering shaft without it.
I bought a reproduction Tuff Wheel adapter at the Mopar Nats last year. Once I got it home, I found out that it is slightly warped where the base is welded. I'm not sure if all the repros are like this or if I got a blem. Just something to think about...
