Bad Launch with 572 ! up -down up -down !
#2493623
05/08/18 01:39 PM
05/08/18 01:39 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Hi Guys .. yesterday tried first time my new 572 .. but some problem with or without nitrous ... at Launch engine go up down... up down ... RPM ! look like bad converter stall ... any idea ?
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
Re: Bad Launch with 572 ! up -down up -down !
[Re: Raffaplymouth60]
#2493693
05/08/18 04:54 PM
05/08/18 04:54 PM
Posts: 372 Western NY
maxi426
Western NY
If carbureted check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered?
[Re: maxi426]
#2493694
05/08/18 05:07 PM
05/08/18 05:07 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
If carburated check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered? Sounds like a fuel delivery issue to me.
[Re: maxi426]
#2493820
05/09/18 12:28 AM
05/09/18 12:28 AM
Posts: 1,505 TN
SCATPACK 1
TN
If carbureted check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered? Sounded like fuel issue to me too.
Old Geezer Racing
#2493867
05/09/18 09:26 AM
05/09/18 09:26 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
SEEMS MORE LIKE CHASSIS IS LOADING AND UNLOADING?????
JAKES AUTOMOTIVE
[Re: maxi426]
#2493937
05/09/18 01:35 PM
05/09/18 01:35 PM
Posts: 195 Italy
Raffaplymouth60
Italy
If carbureted check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered? yep is 1050 Dominator ! when i have checked bowl level and was ok but after pass the rear bowl was low .. but after 5 minute when come back at my box was ok ... very strange ....Fuel Pump is Aeromotive A2000 all 10AN Fuel Line ... im also think the problem is possible on furl line issue
[Re: sgcuda]
#2493938
05/09/18 01:36 PM
05/09/18 01:36 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Sounds like fuel, but I'd like to see a side shot of the run to check for any wheel hop. im working for put a video from Side
[Re: an8sec70cuda]
#2493939
05/09/18 01:38 PM
05/09/18 01:38 PM
Posts: 195 Italy
Raffaplymouth60
Italy
If carburated check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered? Sounds like a fuel delivery issue to me. hi ! im Race with Old 496 Combo from 10 years ... never problem .. 9.2@150 ... with new 572 .. the ET drop to 9.6 9.8 with this problem
#2494022
05/09/18 04:48 PM
05/09/18 04:48 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Are you hitting the NOS on that run with that surging? How about a piece of fuel line on the front fuel bowl vent to route any splashed or sloshed fuel away from the carb opening? Do you have jet extensions on the rear jets?
#2494038
05/09/18 05:23 PM
05/09/18 05:23 PM
Posts: 4,457 Washington
madscientist
Washington
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires.
[Re: madscientist]
#2494075
05/09/18 07:10 PM
05/09/18 07:10 PM
Posts: 195 Italy
Raffaplymouth60
Italy
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires. i had this suspension setting from many years .. Caltracs, Dana 60,monoleaf ..i have onky swap the engibe from 496 to 572 .. same transmission same axle ... same tires only change Engine .. the only difference is the weight .. 572 weight is 80 lb more than 440 block .. i think ..you think this can cause unloading rear tires?
[Re: Cab_Burge]
#2494076
05/09/18 07:14 PM
05/09/18 07:14 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Are you hitting the NOS on that run with that surging? How about a piece of fuel line on the front fuel bowl vent to route any splashed or sloshed fuel away from the carb opening? Do you have jet extensions on the rear jets? Hi ! i dont understand how put a piece of fuel line .. from bowl vent to ?? i don't have Fuel Jet extension..
#2494081
05/09/18 07:28 PM
05/09/18 07:28 PM
Posts: 69 Palm City, FL
Dadodgekid
Palm City, FL
So everything stayed the same from your 496 to the 572? whats your idle fuel pressure set to? I hear engine surge... timing or fuel. rear tire is planted pretty good in your video. Almost sounds like the converter is too tight??
