1965 Dodge Coronet 500
#2492781
05/06/18 01:37 PM
05/06/18 01:37 PM
Posts: 31,046 Oregon
AndyF
I've had this car for a long time. It was a street racer back in the 70's and then a daily driver during the 80's. It sat in my shop for most of the past 20 years. I'm now starting to work on it a bit and hope to have it back on the streets this summer.
Re: 1965 Dodge Coronet 500
[Re: basketcase]
#2492836
05/06/18 04:40 PM
05/06/18 04:40 PM
Posts: 4,684 Wichita
GY3
Wichita
One of my favorite cars on Moparts!
[Re: AndyF]
#2494111
05/09/18 09:12 PM
05/09/18 09:12 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I weighed the car today and found out that it is heavier than I thought. Good news is the weight distribution is pretty good. 51% up front and 49% in the rear. The gas tank is almost empty so if I filled up the tank the car would have a 50/50 weight distribution front to rear. The bad news is that the car is almost 3800 lbs with nobody in it. If I filled up the gas tank the car would weigh over 3800 lbs. Isn't gasoline about 6 lbs/gallon? I'd imagine with an extra 12 gallons, it would weigh almost 75 lbs more. Still cool you'd be able to achieve almost 50/50. How did you do it? Fiberglass body panels?
[Re: AndyF]
#2494130
05/09/18 10:08 PM
05/09/18 10:08 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
If I filled up the gas tank the car would weigh over 3800 lbs. Curb weight... Thirty-four hunert OEM...
[Re: MuuMuu101]
#2495358
05/13/18 12:58 AM
05/13/18 12:58 AM
AndyF
I weighed the car today and found out that it is heavier than I thought. Good news is the weight distribution is pretty good. 51% up front and 49% in the rear. The gas tank is almost empty so if I filled up the tank the car would have a 50/50 weight distribution front to rear. The bad news is that the car is almost 3800 lbs with nobody in it. If I filled up the gas tank the car would weigh over 3800 lbs. Isn't gasoline about 6 lbs/gallon? I'd imagine with an extra 12 gallons, it would weigh almost 75 lbs more. Still cool you'd be able to achieve almost 50/50. How did you do it? Fiberglass body panels? No fiberglass, the body is all steel. The 50/50 weight is due to having the battery in the trunk as well as having a fairly lightweight engine. Aluminum heads, aluminum intake, aluminum carb, mini starter, aluminum water pump housing, aluminum radiator, etc.
[Re: AndyF]
#2556624
09/30/18 01:45 PM
09/30/18 01:45 PM
AndyF
[Re: AndyF]
#2567613
10/22/18 12:58 AM
10/22/18 12:58 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Cool project, Andy. I love the '65's. I thought they were a little lighter, as well.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: dmoore]
#2697012
09/12/19 09:09 PM
09/12/19 09:09 PM
Posts: 176 Atco NJ
Mr Bojangles
Atco NJ
I was thinking the same thing !
1965 Belvedere II 440 4psd 4.10 Driver
1966 Belvedere II Race Car Project
1970 Duster Street Car Project
2003 Hemi Ram Quad Cab 4x4
