Wide Band install question
#2492258
05/05/18 01:14 AM
05/05/18 01:14 AM
Posts: 1,675 Mi.
G-Money1320
Mi.
I will be installing Wide Band in my car soon and need opinions as to where to weld in the bung for the 02 sensor. The instructions say 18" from the exhaust port or at least 36" if running race fuel ( which I do). My question is since I am going to up my exhaust to 3" can I put the bung in the pipe just after the header or will that be too far away and better in the header?? Thanks!! Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
Re: Wide Band install question
[Re: G-Money1320]
#2492279
05/05/18 02:02 AM
05/05/18 02:02 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
I had mine welded in on the head pipe side going towards the rear of the car right at the collector flange with a full length 3.0 inch exhaust system with straight through muffs mounted at the rear bumper behind the rear end I ended up making it a dual wide ban system later so I could read both sides at the same time before adding the hardware and software to read both sides I would swap the O2 sensor from side to side My message is do it once and do it correct with both sides working from the start
[Re: hemi-itis]
#2492434
05/05/18 02:01 PM
05/05/18 02:01 PM
Thumperdart
State of confusion
Think it's like 8 to 10 inches from the collector. This is how I did mine..........8-10" past the MERGE not the flange where the exhaust bolts up to unless you have race headers then no flange of course...........
[Re: Twostick]
#2492801
05/06/18 02:26 PM
05/06/18 02:26 PM
Thumperdart
State of confusion
More room on the passenger side. No shifter or kickdown linkages, no cooler lines.
Kevin Exactly for a single read unit........
