Re: 1972 Charger SE Project by CDN72SE
[Re: CDN72SE]
#2491569
05/03/18 04:19 PM
05/03/18 04:19 PM
Posts: 428 Oakville, Ontario, Canada
CDN72SE
Interior Rear Quarter interior panel and support:Or whatever it is called. :scratchchin: Cleaned up the panels and sprayed them with some gloss black paint: And applied some of that caulk from DMT to replace what was there, think it was there so the panel and the support didn't make any rattling noise. I'll install them after I get the rear quarter windows in.
[Re: CDN72SE]
#2492968
05/06/18 11:03 PM
05/06/18 11:03 PM
Posts: 1,487 STL
cdstl
STL
Beautiful.
A word of advice. I would remove any and ALL RPM that you put onto your metal parts and PAINT them with something that will resemble their factory appearance. RPM is just that, rust PREVENTION and it will be MAJIC if they don't re-rust inside of a year.
If you plan on driving your car and not leaving it in a climate controlled bubble, your parts WILL rust again.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: CDN72SE]
#2513230
06/25/18 09:26 PM
06/25/18 09:26 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Wow
Wow
Wow
Just Beautiful!!!
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
