Is there a gasket between MC and Booster?
#2491312
05/03/18 08:03 AM
05/03/18 08:03 AM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Should I use a paper gasket or foam between MC and Booster? Can’t recall if factory did... Thanks
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
Re: Is there a gasket between MC and Booster?
[Re: 440PURSUIT]
#2491504
05/03/18 02:36 PM
05/03/18 02:36 PM
Posts: 25,969 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Gasket, Tandem Master Cylinder Mounting 2401862. All models up through '72.
[Re: 440PURSUIT]
#2492272
05/05/18 01:37 AM
05/05/18 01:37 AM
Posts: 765 Shoreline, Washington
72roadrunnergtx
Never saw a factory installed gasket between M/C and the booster, matter of fact there is a grove stamped into the booster at the booster-M/C mating surface to allow any brake fluid weepage to drain rather than collect in the booster. Foam gaskets were used on manual brake cars, M/C to firewall backing plate.
