Improve a pre 2009 5.7L How? #2489952
04/30/18 01:32 PM
04/30/18 01:32 PM
SC
V194 Offline OP
V194  Offline OP
SC
What 5 things would you do to add more power to a pre 2009 5.7L. (short of forced induction, turbo, nitrous)?
Re: Improve a pre 2009 5.7L How? [Re: V194] #2489963
04/30/18 01:45 PM
04/30/18 01:45 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Eagle Heads And intake manifold, SRT 6.1 Cam , Headers and A good tune.
If the Eagle heads are too much compression, then go and get 6.1s.
You can port the pre Eagle heads and get good results.
that's my 5.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Improve a pre 2009 5.7L How? [Re: V194] #2490016
04/30/18 03:14 PM
04/30/18 03:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I pretty much agree with ric. Also I would not be afraid of the compression, I measured one and it came to 11.5, the 6.4 has 10.9 from the factory so your only 1/2 point over that, run premium pump fuel, you will get improved MPG from the compression and it will not cost much if any more in the end. These motors are very detonation resistant.
Re: Improve a pre 2009 5.7L How? [Re: V194] #2494624
05/11/18 02:15 AM
05/11/18 02:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Lets say a guy has a 2007 Ram 1500 and has to pass emission testing. Can the above possibly comply ? In California, the testing consists of a scan of the OBD2 system and a visual smoke test. If the computer shows no codes, it passes.
What kind of power increases can one expect while still being compliant? The stock rating is 345 HP.
I have 306,000 miles on mine. It runs fine but has surely lost some power. It leaks nothing but burns oil.
Re: Improve a pre 2009 5.7L How? [Re: V194] #2494785
05/11/18 03:14 PM
05/11/18 03:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the headers may give you a code for "slow cat warm up" "slow O2s response" or something to that effect and will not bolt right up to the exhaust, if were talking shorties they aren't worth the bother anyhow. A tune may be able to eliminate that but if they visually look it won't look stock and they may need to see a carb EO number. Maybe you help the exhaust and still look stock enough with an exhaust system from an 09 3/4 or 1 ton hemi truck, it flows way better and looks like, well a stock system.
The cam might give you a misfire code but I have not seen that problem myself. Again a tune should be able to cure that.
Overall you should be able to do all that with no issues except possibly the headers. Obviously don't mention that you have a non stock cam or heads while at the testing station.
You probably should be looking at a high flow intake also as you need to flow a lot more air in to match the higher flow after it, probably need to find one that has a carb EO number or put the stock one on during testing. They still have a looky around under the hood don't they?
Re: Improve a pre 2009 5.7L How? [Re: V194] #2494889
05/11/18 08:29 PM
05/11/18 08:29 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I am a bit embarrassed to admit that I am out of the loop on what they actually do. I recall before OBD2, they did a visual check to ensure all equipment was in place, a probe in the tailpipe to measure emissions and a vacuum check of the gas cap. Nowadays, all that I am sure of is that they do not sniff the exhaust on OBD2 vehicles.
The truck is not a slug but I figure that if I do rebuild an engine for the truck, why not step it up a little.
Re: Improve a pre 2009 5.7L How? [Re: V194] #2494932
05/11/18 10:38 PM
05/11/18 10:38 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
With tuning software you can actually mark stuff not to report... which won't show up in an emissions test, meaning it would pass. I'm not saying to do this, probably illegal, but can be done.
Basically emissions checks for stored codes and there are readiness monitors. Like for o2 sensors, evp system etc.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Improve a pre 2009 5.7L How? [Re: V194] #2495021
05/12/18 09:55 AM
05/12/18 09:55 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
There are some C.A.R.B legal headers, the 6.1 cam won't throw a code, if tuned , some one like Jay Green can write you a tune that will work, and even spec a cam that will pass.
