Heat Riser Valve #2489281
04/28/18 11:46 PM
04/28/18 11:46 PM
NC
Sixt8Chrgr Online content OP
Sixt8Chrgr  Online Content OP
NC
I need to rebuild my heat riser valve in my exhaust manifold. I have a 69 Charger with a 440. Have looked everywhere and can't locate replacement or a rebuild kit. Any one know where I can buy one?
Re: Heat Riser Valve [Re: Sixt8Chrgr] #2489299
04/29/18 12:24 AM
04/29/18 12:24 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Re: Heat Riser Valve [Re: HEMICUDA] #2489308
04/29/18 12:44 AM
04/29/18 12:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Heat Riser Valve [Re: Sixt8Chrgr] #2489401
04/29/18 10:20 AM
04/29/18 10:20 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do you need everything or just pieces ?
Re: Heat Riser Valve [Re: 62maxwgn] #2489429
04/29/18 11:23 AM
04/29/18 11:23 AM
NC
NC
The original is in the exhaust manifold but it does not open and close, and also leaks spent gases on the block. So not sure what I would need to make it work? Be happy to buy whatever it would take.
Re: Heat Riser Valve [Re: DAYCLONA] #2489430
04/29/18 11:25 AM
04/29/18 11:25 AM
NC
NC
Originally Posted By DAYCLONA
Thanks very much for sending that link. I looked everywhere.
