Page 3 of 3 1 2 3
Re: Truck to pull enclosed trailer [Re: 6PKRTSE] #2486975
04/23/18 09:23 PM
04/23/18 09:23 PM
fresno ca
mikeysmopars Offline
fresno ca
I like my new one, pulls 24 foot trailer loaded down with everything I can for, maybe 10k total.
2500 diesel.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Truck to pull enclosed trailer [Re: mikeysmopars] #2486981
04/23/18 09:42 PM
04/23/18 09:42 PM
birdtracker Offline
birdtracker  Offline
I tow with an old 93 2wd dually. Its an automatic. Has pulled a 24 and a 26 foot enclosed with no problem. Birdtracker
Re: Truck to pull enclosed trailer [Re: Aspen7695] #2487000
04/23/18 10:39 PM
04/23/18 10:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
You will absolutely LOVE the drivability of the new diesel! You’ll also be happy to hear that they are much “happier” doing daily driver duties than their pre DEF years. Do your homework, there are gear ratios from 3.42, 3.73, 4.10. Picture this: coming up on the Cajon Pass with the cruise set at 55 and I just sat back and let the truck do the work.... all the way down that gawd awful grade. I was impressed. This was my friends 15 2500 4x4. It was a pleasure to tow with over my modded 01 for sure!
Re: Truck to pull enclosed trailer [Re: J_BODY] #2487097
04/24/18 02:18 AM
04/24/18 02:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
I learned to love my 1998 1/2 24 valve extended cab short bed two wheel drive automatic with 3:54 rear gear Ram 2500 in the summer of 2001 or so when towing my 24 Ft Pace Shadow weighing right at 8600 Lbs. going up the Baker grade on I15 going to race at Las Vegas in August in the early afternoon with 117 F outside air temps, I kicked it out of O.D. at the bottom of the grade, had the cruise set at 70 MPH and the air conditioning on high cool. I blew past a similar year Dodge 2whd V10 3/4 ton pulling the twin trailer to mine about a mile up the road from the bottom of the grade, that grade is 18 miles straight uphill from the bottom at 800 Ft to the top about 18 mile later at 4400 Ft. with one small dip about 15 miles up it. I could not see the V10 in my mirror at the dip devil It went over the top of the grade at 70 MPH and the coolant temp had risen to around 220 from the normal 190 cruising temps. in the summer down there boogie
I moved to Oregon in the summer of 2005 and bought my 2006 ram 3500 4 whd due to getting stuck in the snow multiple times here in the winter of 2005/2006 down
9SecondPhil bought my old truck and put over 500,000 miles on it towing trailers all over our country before he was killed on that dang Harley in Florida whiney RIP my friend up
Re: Truck to pull enclosed trailer [Re: Aspen7695] #2487159
04/24/18 10:04 AM
04/24/18 10:04 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
We have a '95 2wd diesel dually with a sure-grip rear. Only ever had it stuck in the snow...with a trailer on it. I keep winter tires on it. I don't drive it that much.
Bought an '04 dually 4x4 diesel a few years back. Love it. 3.73 gears. Pulls great. I don't care how big the trailer is behind it, it gets 11 - 12 mpg at 70 mph.
Re: Truck to pull enclosed trailer [Re: Aspen7695] #2487182
04/24/18 11:28 AM
04/24/18 11:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I was mainly talking about the exhaust braking and shift strategy Cab..... these newer trucks have amazing control compared to older ones. No way I’d crest the drop at Cajon at 55-60 in my 01. Downhill speed management requires some attention in my pickup. New ones are practically “set it, and forget it”.
Re: Truck to pull enclosed trailer [Re: J_BODY] #2487257
04/24/18 01:47 PM
04/24/18 01:47 PM
My 2006 3500 has the tow control option, I like it a lot up
I'll never go back to gas for towing tsk
Page 3 of 3 1 2 3
