Battery problem #2486404
04/22/18 02:10 PM
04/22/18 02:10 PM
Illinois
Mopar_Ray Offline OP
Illinois
My Challenger goes to the strip, battery is located in the trunk so I need a cutoff switch. The only things on the battery side of the switch is the battery and the alternator, so the switch will kill the motor. Even With the switch off, the battery discharges? What can I do?
Re: Battery problem [Re: Mopar_Ray] #2486433
04/22/18 03:24 PM
04/22/18 03:24 PM
One of two things, you have a bad battery or some thing is hooked up that your not seeing work Is there a Volt meter hooked up to the battery? If so put it on the load, on, side of the switch scope twocents
I sold one of my old drag cars to a friend, he hooked the volt meter up on the battery side of the cut off switch, which would kill the battery pretty quickly, 3 to 5 days with nothing else on tsk scope
Re: Battery problem [Re: Mopar_Ray] #2486563
04/22/18 10:00 PM
04/22/18 10:00 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Had same problem last year. Alternator had a bad diode. Would drain battery over night.
Re: Battery problem [Re: Mopar_Ray] #2486619
04/22/18 11:49 PM
04/22/18 11:49 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Alternator
