Block heater, oil or water #2485332
04/19/18 11:24 PM
04/19/18 11:24 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What are you guy;s using ?
Re: Block heater, oil or water [Re: rowin4] #2485337
04/19/18 11:32 PM
04/19/18 11:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
My Son bought his from Jegs and pretty sure he only has one going into a soft plug hole. Later in the year when we run the Halloween races in PA and Ohio he loves them. It saves him a lot of alcohol.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Block heater, oil or water [Re: rowin4] #2485347
04/19/18 11:52 PM
04/19/18 11:52 PM
rowin4 Offline OP
rowin4  Offline OP
I have the World block with screw in plugs, does anyone make screw in heaters?
Re: Block heater, oil or water [Re: rowin4] #2485350
04/19/18 11:55 PM
04/19/18 11:55 PM
PA.
"Little"John
"Little"John
PA.
Not sure about the screw in but I would give Jegs a call
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Block heater, oil or water [Re: rowin4] #2485360
04/20/18 12:13 AM
04/20/18 12:13 AM
I don't have either but all the bucks up racers I know that do use electric heaters in their racers use them in the oil dry sump reservoir up Hot oil with cool water usually equals going faster also work
Oil takes longer to heat up so I would use one in the oil somewhere up twocents Heats rises, correct work grin
Re: Block heater, oil or water [Re: pittsburghracer] #2485361
04/20/18 12:15 AM
04/20/18 12:15 AM
PA.
"Little"John
"Little"John
PA.
If you don’t have any luck go to the google box and type in screw in block heaters. A bunch come up. If you don’t find what you are looking for you can always modify you radiator and install one
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Block heater, oil or water [Re: rowin4] #2485403
04/20/18 01:34 AM
04/20/18 01:34 AM
rowin4 Offline OP
rowin4  Offline OP
O'Reilly has some immersion type heaters that might be able to adapt into the radiator, just drill a hole and pull it through from the inside and it seals with 2 o-rings and cap nut,. Zerostart #8600880 1500watt should heat the recirculated water faster than I can check the air in the tires.
Re: Block heater, oil or water [Re: rowin4] #2485433
04/20/18 02:55 AM
04/20/18 02:55 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My buddy used to run a heater on the oil pan and one on the trans pan in his Stocker.
Re: Block heater, oil or water [Re: Cab_Burge] #2485436
04/20/18 03:56 AM
04/20/18 03:56 AM
Washington
madscientist Offline
Washington
I thought it was thin oil and cool water? I've never heated thin oil. Ever. I'm talking 0W20 or even 5W30.
Re: Block heater, oil or water [Re: madscientist] #2485445
04/20/18 04:26 AM
04/20/18 04:26 AM
Maybe you should scope
Have you ever set a NHRA record in stock or Super stock? work
I have helped several NHRA racers due that up
Any grade oil hot flows a lot easier with less resistance as you know, correct work
Re: Block heater, oil or water [Re: rowin4] #2485593
04/20/18 01:33 PM
04/20/18 01:33 PM
rowin4 Offline OP
rowin4  Offline OP
OK , maybe I should have asked , oil or water preheat should be used with a World Products Hemi aluminum block with aluminum heads to bring the engine up to tolerances with out running the engine for 10 minutes before a run.
Re: Block heater, oil or water [Re: rowin4] #2485605
04/20/18 02:05 PM
04/20/18 02:05 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I would heat the oil. It will stay warmer longer and heat from the very inside out. It was 30 something degrees in Dallas last weekend and I left the dry sump oil heater plugged in all morning. I would get the tank warm to the touch and spin the pump to circulate the oil through the system. Probably 5-6 times as things cool off quickly at maybe 40 degrees in the wind. You could do the same thing with a wet sump and a priming rod. Take the cap off, roll the engine around to the timing mark or #1 @ TDC firing, pull the distributor and the shaft and circulate away. 3 screws is no big deal...Run the engine, trans. and rear on the stands to get the water temp. where you want it.
Re: Block heater, oil or water [Re: rowin4] #2485627
04/20/18 02:56 PM
04/20/18 02:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Coolant temp affects block/head (especially aluminum) dimensions more than oil temp. Warm oil flows more quickly on startup than cold oil.
Longevity is definitely improved by avoiding condensation & heating engines before starting them.
We always heated everything up on the serious road-racing & sprint-car stuff, and at the drags, run everything on stands before 1st pass. Let the coolant temp drop a bit before a pass as already noted.
Re: Block heater, oil or water [Re: Dave Hall] #2485645
04/20/18 03:33 PM
04/20/18 03:33 PM
rowin4 Offline OP
rowin4  Offline OP
Well noted on the Dallas race. I was talking to a guy Wednesday night that was racing there. He said it took him a half hour to get his alcohol engine started. That's what got me to thinking about putting some heat in the engine before starting. Priming would not be a problem for me as I run a remote distributor with the distributor plug.
Re: Block heater, oil or water [Re: rowin4] #2485823
04/20/18 10:22 PM
04/20/18 10:22 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It's a pretty common deal in T/S and T/D. All the dry sump tanks have heaters and everyone I know runs the pump before starting. If it's the middle of summer we just prime the system without the heat.
Re: Block heater, oil or water [Re: Dave Hall] #2485844
04/20/18 10:59 PM
04/20/18 10:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I built my dry sump tank.. no heater but I have
one in the trailer.. I slip the belt off and
prime the oil system in the mourning.. I let
the heater run while I drive to the track..
about a hour and 10 minutes away to the closest
track.. most times its at about 120* or better..
I use a inverter while driving with a 120v heater
wave
Re: Block heater, oil or water [Re: madscientist] #2485901
04/21/18 01:24 AM
04/21/18 01:24 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
0w 20 is my heavy oil 0 w 5 is my light oil.. I also feel that warm oil returns back to the pan quicker than cold oil.. especially when under lots of vacuum popcorn
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Block heater, oil or water [Re: rowin4] #2486037
04/21/18 12:57 PM
04/21/18 12:57 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I've read some bad comments about attaching a heat pad to the pan - even some name brands do not shut off when they reach a temperature high enough to be dangerous.
Water is safer since the large volume isn't going to boil.
Water is the only way to get the cylinders warm.
Bill Jenkins 40 years ago: use QD and large hoses to connect hot water from your truck to the race engine. Great for that 1st start-up.
Boffin Emeritus
Re: Block heater, oil or water [Re: rowin4] #2486062
04/21/18 01:59 PM
04/21/18 01:59 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
If you run methanol and your trying to preheat things you might consider a primer plus system. I run methanol, I have a pan heater as well as a 2 block heaters. I dont use them any more.I really like the primer plus system as it saves a TON of fuel and I can drive the car around the pits using it. I built my own, but you can purchase them from Rons Fuel injection. Yes I use it under my carb.
Re: Block heater, oil or water [Re: rowin4] #2486232
04/21/18 11:31 PM
04/21/18 11:31 PM
rowin4 Offline OP
rowin4  Offline OP
My buddy uses the primer plus system , works really well as he is on methanol. I have a all aluminum motor on gas. Right now I'm leaning to heating the water to bring the block up to expanded tolerance. I been thinking about this aluminum block thing and years ago there were a lot of factory engines that were total aluminum. Don't recall any startup and run procedures.
