Help I.D. Steel Wheel #2483317
04/15/18 09:50 PM
04/15/18 09:50 PM
Maryland
ro23_j Offline OP
ro23_j  Offline OP
Maryland
I have a 15" x 5 1/2 JJ steel wheel and am trying to determine the application. It is stamped Kelsey Canada with K2 8, 11 20. Photos attached. Any info appreciated.
Thanks,
IMG_1512 (1024x768).jpgIMG_1513 (1024x768).jpgIMG_1516 (1024x768).jpgIMG_1517 (1024x768).jpg
Re: Help I.D. Steel Wheel [Re: ro23_j] #2483388
04/16/18 12:16 AM
04/16/18 12:16 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
It's a 1968-9 style wheel. Kelsey-Hayes, plant 2, looks like November 20, 1968 build date. Could have gone on a C-body, or a B-body. This wheel would have covered many different models - maybe even pickup trucks. Not a valuable wheel.
Re: Help I.D. Steel Wheel [Re: ro23_j] #2483412
04/16/18 01:09 AM
04/16/18 01:09 AM
A727Tflite Offline
A727Tflite  Offline
What would a good set of 4 sell for - I'm looking for a set myself - to replace the 14" steels on my 62 Plymouth.
Re: Help I.D. Steel Wheel [Re: ro23_j] #2483423
04/16/18 01:34 AM
04/16/18 01:34 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
This 15x5.5" is a 1969 C body wheel. 11-20-1968
Re: Help I.D. Steel Wheel [Re: Sunroofcuda] #2483892
04/16/18 10:07 PM
04/16/18 10:07 PM
Maryland
ro23_j Offline OP
ro23_j  Offline OP
Maryland
Thanks for the replies, I appreciate the info.
Re: Help I.D. Steel Wheel [Re: A727Tflite] #2484421
04/17/18 11:14 PM
04/17/18 11:14 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Should be $100/set at the junkyard if you're not concerned about running the correct dog dish caps.
Several choices available if you want to run the correct caps.
Re: Help I.D. Steel Wheel [Re: 64Post] #2484437
04/17/18 11:51 PM
04/17/18 11:51 PM
A727Tflite Offline
A727Tflite  Offline
Thanks for the reply. I have a correct set of 14's with the large pattern for the correct dog dishes but I think the car would look puny without 15's.
I have a remedy for the small center to use the large dog dish so going to chase that down first.
Re: Help I.D. Steel Wheel [Re: A727Tflite] #2484446
04/18/18 12:11 AM
04/18/18 12:11 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Screws or epoxy are the usual low-buck solutions.
Re: Help I.D. Steel Wheel [Re: A727Tflite] #2484551
04/18/18 11:15 AM
04/18/18 11:15 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not to mention the availability of 14" tires is practically nonexistent.
I have mechanical Aptitude.
I can screw up anything.
Re: Help I.D. Steel Wheel [Re: ro23_j] #2484648
04/18/18 03:14 PM
04/18/18 03:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
14" tires aren't that hard to find. Try Discount or tire rack. They list a bunch of them.
Re: Help I.D. Steel Wheel [Re: ro23_j] #2484682
04/18/18 04:12 PM
04/18/18 04:12 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I now have access to a supply of 15x5" wide pre-68 wheels. Just got a set in. These will accept the larger diameter 67 & earlier dog dish caps. They can be widened, but I do not do any wheel mods. I have not had a pre-68 Mopar wheel in over 3 years. Only other ones I used to get in 15" were 5.5" wide.
Re: Help I.D. Steel Wheel [Re: Sunroofcuda] #2484856
04/18/18 10:41 PM
04/18/18 10:41 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm getting ready to sell off 2-15 X 5, 2-15 X 5.5 and 2 widened 15 X 8. All of them are/were K wheels.
Now that the large cap centers are available for the 15" rim shells the K wheels just aren't the only option anymore. They still bring good money though.
