Question for 71-74 B Body owners with factory A/C
#2483881
04/16/18 09:57 PM
04/16/18 09:57 PM
Posts: 1,074 So Cal, USA
Fab64
So Cal, USA
Hi all, 1971 Satellite Sebring Plus,with factory A/C. I'm preparing to put my A/C-Heater box back in, and noticed this rubber thingie in the firewall, just below the blower motor. Interior side: https://photos.app.goo.gl/CfwDcvPFMCfLqW8K2Engine compartment side: https://photos.app.goo.gl/RCHABaDayGsUg8Ez1Is this supposed to be connected to something? It doesn't go anywhere on the engine side. Is it possible someone cut it off? My factory service manual just shows something there; it doesn't say what it is. All suggestions appreciated, thanks. Roger
Re: What is this below A/C box, a drain of some sort?
[Re: Fab64]
#2483928
04/16/18 10:51 PM
04/16/18 10:51 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Vacuum hoses, for the heater valve ?
[Re: Fab64]
#2483933
04/16/18 11:02 PM
04/16/18 11:02 PM
Posts: 5,778 ohio
ruderunner
ohio
Basic evaporator drain. Make sure it's not clogged. Connected to the heater box and passed through the firewall. Turns down and dumps condensed water from the heater box outside the passenger compartment.
Angry white pureblood male
[Re: ruderunner]
#2483964
04/16/18 11:58 PM
04/16/18 11:58 PM
Fab64
So Cal, USA
Thanks for the suggestions so far, but I think I figured out part of the mystery. The "Inlet Air Door actuator" is located on the forward part of the A/C box, right next to the firewall: https://photos.app.goo.gl/DRzmSE9Gflk37WM43There are two vacuum lines that operate this actuator, and two more that hang down past the actuator. I believe these latter two are supposed to connect to the lines on this firewall plug (one is larger than the other). They appear to have been broken or cut off, likely by a previous owner. Does anyone know if something goes on the other side of the firewall, or are these perhaps just vent lines for the Heater-A/C controls? Btw, the evaporator drain line comes directly out of the lowest part of the A/C box, directly through the firewall (the downward-facing tube to the right and below the blower motor in the above pic).
