Re: 440 Engine Block best production years!
[Re: SunnyMopar]
#2483209
04/15/18 06:43 PM
04/15/18 06:43 PM
RapidRobert
Sonny welcome aboard. (fasten your seat belt!). See if Andys 440 manifesto is in the archives. EDIT I looked & saw the 451 manifesto which ain't it but someone will point you to it plus offer more info on your Q.
[Re: SunnyMopar]
#2483244
04/15/18 08:00 PM
04/15/18 08:00 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
Mopar used the same casting numbers on the 440 blocks from 1966 to late 1971 blocks. Starting in early 1972 they changed the casting numbers on the 440 passenger car motors only, HD, industrial and marine motors weren't changed ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) The main thing you need to know about is if that motor is internally balanced or externally balanced ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) If the seller doesn't know see if the crankshaft balancer has a oblong external ring around it or not, if it does it means it is externally balanced and that balancer should say for 440 motors cast into it ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) If it doesn't have a balancer like that and does NOT shake when running up through 5000 RPM then it is probably internally balanced, ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) The bad thing about externally balanced Mopar V8 is Mopar used external weights on both ends of the crankshaft on the flywheel or converter with weights welded onto the converters Please let us know what you find out
[Re: SunnyMopar]
#2483415
04/16/18 01:13 AM
04/16/18 01:13 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
If it’s priced right snag it. Check to your comfort level.
Unfortunately when you go to sell that car people will get all twisted up, contorted, and maybe have seizures when they find out you put a bad year, off year, or whatever they call it block in it. Because that matters a lot. Just talk to joe average. He’ll tell you. Can’t do that. Not allowed. Against rules. Nope.
“Know what ya shoulda done...”
I want my fair share
[Re: Cab_Burge]
#2483439
04/16/18 02:19 AM
04/16/18 02:19 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
if the crankshaft balancer has a oblong external ring around it or not, if it does it means it is externally balanced and that balancer should say for 440 motors cast into it Edit Cab Should say "CAST CRANK ONLY" ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2483446
04/16/18 02:51 AM
04/16/18 02:51 AM
Cab_Burge
if the crankshaft balancer has a oblong external ring around it or not, if it does it means it is externally balanced and that balancer should say for 440 motors cast into it Edit Cab Should say "CAST CRANK ONLY" Not always, the 1970/71 forged steel crankshaft HP motors with the big heavy six pack rods didn't have that written, cast, on them with that external cast in weight ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: SunnyMopar]
#2483529
04/16/18 11:39 AM
04/16/18 11:39 AM
Posts: 4,793 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Can a pistons proximity to zero deck be determined without pulling off a head and measuring? The thought of a Six Pack on top of smogger dogger type pistons makes me sad.
Keep old mopars alive.
[Re: SunnyMopar]
#2483568
04/16/18 01:09 PM
04/16/18 01:09 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
A bore scope can help you determine the pistons, dished or flat tops, there might even be a part number on top of pistons that can be seen. I think it would be worth a try.
Have a great day Iowan
"obsolete is neat"
[Re: SunnyMopar]
#2483628
04/16/18 03:06 PM
04/16/18 03:06 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
In my opinion, all years 440 blocks are just fine unless you have a blower, 3-stages of nitrous, etc. with more than maybe 600-650 horsepower. Also, 74+ blocks use a larger lip on the center main bearing which is preferred, but not required.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: SunnyMopar]
#2483795
04/16/18 07:34 PM
04/16/18 07:34 PM
Posts: 8,911 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Can a pistons proximity to zero deck be determined without pulling off a head and measuring? The thought of a Six Pack on top of smogger dogger type pistons makes me sad. Why ... a "six pack" is just a 2 bbl motor until the vacuum kicks in the outboard carbs. And unless you plan to race the thing , who cares if its down on power a bit.
