Re: Testing a blower resistor
[Re: QuickDodge]
#2483775
04/16/18 06:53 PM
04/16/18 06:53 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Yes you can do a ohm test on each of the speed resisters, but its just easier to take it out and look at it or measure it to tell if its bad. It should be apparent if it is bad.
But, I'm going to say as old as the truck is, its no doubt the resister, or/and the connecter itself as well may be fried . Get it apart and look at it, its probably already been changed before, maybe even a couple of times.
[Re: QuickDodge]
#2484121
04/17/18 11:27 AM
04/17/18 11:27 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Typically if high only its the resistor.But they did have lots of problems with the switchs those years.Rocky
Chrysler Firepower
[Re: QuickDodge]
#2484238
04/17/18 02:57 PM
04/17/18 02:57 PM
therocks
Niles , Ohio
moparx dont feel bad days i forget my name it seems.Just remember the switchs because I changed tons at work and on my own.The resistors for the most part in older cars lasted forever.But i have seen them go bad.pretty easy to test just use the old Ohm meter.Rocky
Chrysler Firepower
[Re: therocks]
#2484466
04/18/18 01:26 AM
04/18/18 01:26 AM
Sport440
Canton, Ohio
Typically if high only its the resistor.But they did have lots of problems with the switchs those years.Rocky Like you stated, if high only, most of the time its the resister. But it could be the switch as well. The resister takes most of the abuse though. But the motor , resister , switch and its connecters all work together and can be effected. If the motor starts to draw to much current it can overload both the switch and the resister. The weakest link goes first. Typically the resister takes most of the abuse. A lot of times when it goes, it can take out the connecter as well from the heat that occurs, but not always. If you lose a resister twice in short order, and maybe a switch as well, start looking at the motor. Its next, but for the OP, I'm betting the resister, hope he replies back to what he finds.
Re: Testing a blower resistor -UPDATED
[Re: QuickDodge]
#2484892
04/19/18 12:12 AM
04/19/18 12:12 AM
Posts: 3,391 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
You have verified you are getting power at all switch positions. You have found no resistance at the resistor. The fan is running on high at all switch positions. As multiple other folks have said, everything points to a bad resistor.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: QuickDodge]
#2484898
04/19/18 12:24 AM
04/19/18 12:24 AM
Sport440
Canton, Ohio
UPDATE:
I removed the resistor and examined the wiring. There are no obvious problems. The wiring harness at the blower resistor connection looks good.
With the blower resistor removed, the fan will still run on high speed. Edit, You are Correct Stumpy, I gave info on Wrong year.
[Re: QuickDodge]
#2484919
04/19/18 01:19 AM
04/19/18 01:19 AM
Posts: 1,160 Cruising!
QuickDodge
Cruising!
One reason for trying to make certain it is the resistor is that I have NOT found a new resistor for this truck yet. Anywhere at any price. The resistor for a 1985 is readily available and cheap.
If I'm reading it correctly, the wiring diagram indicates the current flows from the fuse panel to the switch, then to the resistor and on to the motor. I'm NOT very confident that this diagram is correct. Some of the things I see on the truck do NOT match the wiring diagram. Perhaps the wiring diagram is for trucks without air conditioning. Apparently there were some significant differences in the HVAC systems of air conditioned and non air conditioned trucks.
[Re: QuickDodge]
#2484979
04/19/18 09:51 AM
04/19/18 09:51 AM
therocks
Niles , Ohio
Just read supposedlt 87 Ram from NAPA can be used/I know I replaced one in my 83 Ram years ago.Do a google search for the year and resistor.From what i remember they used pretty much the same things for years. Rocky
Chrysler Firepower
