Taller big block oil pump?
#2483321
04/15/18 10:05 PM
04/15/18 10:05 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
After restricting pushrods, I am still a little short on hi rpm oil flow, and am looking for a better rotor and body than a melling hemi hi volume. What works? I do have a steering shaft very close, so a minimal size increase is somewhat important.
Re: Taller big block oil pump?
[Re: gregsdart]
#2483330
04/15/18 10:16 PM
04/15/18 10:16 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
After restricting pushrods, I am still a little short on hi rpm oil flow, and am looking for a better rotor and body than a melling hemi hi volume. What works? I do have a steering shaft very close, so a minimal size increase is somewhat important. Alc/fuel(RCD pictured)pump will push more oil than a Melling or eqivilant HV pump
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: gregsdart]
#2483352
04/15/18 10:56 PM
04/15/18 10:56 PM
gregsdart
I spotted a Milodon segment (gears and outer housing) # 21815 that has a built in second entry, to allow dual line pickup without having to be taller, and i think it will work with my current cover. Anybody use it?
[Re: gregsdart]
#2483417
04/16/18 01:17 AM
04/16/18 01:17 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
It will hold 70+ psi cold, Andy. I would still try shimming it. That has worked for me even when logic says it shouldn't. And it's a cheap easy test.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: gregsdart]
#2483480
04/16/18 09:02 AM
04/16/18 09:02 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I've had good luck with the 21815 pump for years, but I don't know how tall it is compared to a Melling pump height. Always great hot idle pressure and trap pressure. Usually, if anything, it has to be turned down from stock setup. I know that the Milodon covers are massive, due to all of the plumbing going through it.
[image][/image]
[Re: AndyF]
#2483485
04/16/18 09:09 AM
04/16/18 09:09 AM
gregsdart
Try shimming it to see what happens. A HV pump can flow enough oil to overcome a soft spring and force open the bypass. Like Joel says, it is an easy test. Just takes a few minutes to drop a washer or two in behind the spring and see what happens. Thanks, will do. Maybe the volume of oil needed at speed creates more pressure between rotors and the bypass just trying to keep up? another thought is pressure drops as flow in a pipe increases, so the pressure at the back of the motor where the gauge is connected? I saw that at work. Printing ink(thick!) Wouldn't flow through a four inch pipe 150 feet even though the pressure at the pump was maybe 100 psi! Some bean counter was going to save the company money. " we don't need that 6 inch pipe!" We had to go to portable canisters!
[Re: gregsdart]
#2483971
04/17/18 12:16 AM
04/17/18 12:16 AM
Posts: 2,657 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I spotted a Milodon segment (gears and outer housing) # 21815 that has a built in second entry, to allow dual line pickup without having to be taller, and i think it will work with my current cover. Anybody use it? That's a great pump but if you are using the dual line system now with the spacer you will have to buy a midlength oil drive. Milodon 21523 if you are using a bronze gear. The KB pump has 1-1/2 rotors but it uses external filter. I have had one of the aluminum Milodon pumps bind up on me when installed. Can't remember if it was that one or the billlet one. When you are torquing on the oil pump have somebody turning the oil pump with the primer tool and make sure it doesn't start binding on you as you torque it down.
2011 Drag Pak Challenger
[Re: gregsdart]
#2484595
04/18/18 12:52 PM
04/18/18 12:52 PM
gregsdart
Thanks to all that answered, I have lots of ways to skin this cat. From just a washer under the bypass spring, which I figure will help, since you guys say so, to adding the five lobe Milodon pump segment, to going dual line since the 21815 unit will allow it with my tight clearances. I went ahead and ordered the 21815,to get all those options. I am going to use the 21815 and run the single line to it, since it makes a straight on entrance to the lobes, not the 90 degrees of a stock type pump. Also I will start with at least 75 psi cold, unless you guys think I should shoot for 80 cold.
[Re: gregsdart]
#2484684
04/18/18 04:18 PM
04/18/18 04:18 PM
Posts: 200 AB
Efidart
AB
Milodon 21815 here 70 psi cold, 30-40 hot idle and 100-110 WFO. I shimmed the crap out of the stock spring.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
