anti freeze #248301
03/09/09 09:59 AM
03/09/09 09:59 AM
bonney lake washington
W
w2stroker Offline OP
W
from my understanding anti freeze is a no no in a race car because of potential spills at the track. is there anything i can put in my radiator that is acceptable to prevent freezing
Re: anti freeze [Re: w2stroker] #248302
03/09/09 10:23 AM
03/09/09 10:23 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I think Royal Purple had something.
Call Summit they might know.
Snap your neck, mega G-force launch, is all I want!
Re: anti freeze [Re: BDS871Cuda] #248303
03/09/09 12:03 PM
03/09/09 12:03 PM
WA 98043
thecarfarmer Offline
WA 98043
Use salt. Over time, it'll help lighten your block, too...
Okay, seriously, check w/ someone who sells red line products, IIRC their 'water wetter' might have dropped the freezing temp some, and it also helps lube water pump seals.
Oh and about the water... it's s'posed to be better if you use distilled/deionized water; won't corrode up the inside of the engine so bad.
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: anti freeze [Re: thecarfarmer] #248304
03/09/09 12:09 PM
03/09/09 12:09 PM
You are suppose to have NO antifreeze in your coolant system at the track,my track even frowns about those additives too..and with good reason!!!
Re: anti freeze [Re: thecarfarmer] #248305
03/09/09 03:14 PM
03/09/09 03:14 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
Water wetter/Purple ice etc, have no anti freezing
properties.Waterpump lube,anti scaling and foaming,and better cooling are there claims. Chris
