Re: 7290 u-joint issues
[Re: RustyM]
#2482829
04/15/18 12:23 AM
04/15/18 12:23 AM
Posts: 8,033 Tulsa OK
Bad340fish
Tulsa OK
I would upgrade to a billet yoke with the heavy duty thru bolt straps.
68 Barracuda Formula S 340
[Re: RustyM]
#2482832
04/15/18 12:25 AM
04/15/18 12:25 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
Something is wrong other than the straps, they are there to hold the U joint back into the yoke solidly, not to take any of the load from the U joint or driveshaft Yukon sells replacement billet aluminum yoke that comes with U bolts instead of straps for the 8 3/4 rear ends, just like the Mopar stock Dana 60 steel 1330 yokes have
[Re: RustyM]
#2482834
04/15/18 12:27 AM
04/15/18 12:27 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I would take a close look at your yoke. The majority of the u joint cup should be a snug fit in the yoke. The hold down strap is for exactly that, to hold it down. The strap doesn't really take any force. Do you have straps with bolts? I used Moroso aluminum caps for a while. The threaded u joint straps, I'm not sure what upgrade parts there are.
[image][/image]
[Re: RustyM]
#2482845
04/15/18 12:50 AM
04/15/18 12:50 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I have had that happen, found the yoke had spread. Took me a few u joints to figure what the problem was.
[Re: RustyM]
#2482858
04/15/18 01:17 AM
04/15/18 01:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I will bet your U-joint angle is off.. I run the simple little straps with the 4 small bolts.. never broke any of that... thats with a 1.19 60' on a alum 8 3/4 rear EDIT Or your ladder bar angle is off(pinion angle)
[Re: RustyM]
#2482867
04/15/18 01:35 AM
04/15/18 01:35 AM
MR_P_BODY
Headed back from track early with a friend of mine- broke the u-joint straps . Ladder bar car, 512- pinion angle good . Anyone know of better straps than the standard u- bolt style from Mancini etc?
Thanks. If you look at the design you will see that the cups go into the yoke OVER half way... that way all the load is on the yoke.. the bolts or straps are there to just keep the joint from falling out
[Re: MR_P_BODY]
#2482940
04/15/18 07:32 AM
04/15/18 07:32 AM
Posts: 4,700 Wichita
GY3
Wichita
I kept having trouble last season with a 7290 yoke. I used loc-tite on the bolts, torqued properly, etc. I kept breaking one strap bolt and then carnage... Once I got that end fixed with a 1350 yoke and u-bolts, I broke the 7290 FRONT slip yoke! I finally just ordered a new Strange shaft with 1350's at both ends! According to my Virtual dyno, my engine makes 687 ft/lbs. @ 3450rpm. Couple that with its obesity and drag radials and it tends to be hard on driveline parts!
[Re: DoubleD]
#2483026
04/15/18 12:53 PM
04/15/18 12:53 PM
MR_P_BODY
the billet style yoke with the spicer u-bolts is the best solution - those billet caps are actually worse than the stock straps - i would be looking at angle to make sure it is right This is true.. the fancy looking caps are a big problem.. if you lift the car most of those caps rub on the yoke.. that is bad.. your flexing the cap.. you could be causing a vibration at the rear cap
[Re: RustyM]
#2483028
04/15/18 12:56 PM
04/15/18 12:56 PM
sgcuda
If you are breaking straps and bolts, the load isn't staying on the yoke. I think your yoke is spread or worn out, u joint cup is walking off under load.
[image][/image]
