Re: Battery under hood for race car
[Re: AndyF]
#2482727
04/14/18 08:49 PM
04/14/18 08:49 PM
fast68plymouth
So. Burlington, Vt.
In NHRA Stock Eliminator the battery must remain in the stock location....... So, there are plenty of surprisingly quick small tire cars running with the battery up front.
[Re: dthemi]
#2482735
04/14/18 09:10 PM
04/14/18 09:10 PM
Posts: 31,077 Oregon
AndyF
I see Lithium in the driver compartment all the time now, but yet to see one under the hood. I haven't seen that. I wouldn't think that NHRA would allow a battery in the driver compartment. Do they put them in a sealed box or under the floor?
[Re: AndyF]
#2482823
04/15/18 12:20 AM
04/15/18 12:20 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I've seen stock eliminator cars with a master disconnect on the rear panel. That seems really nuts to me unless there is something else going on with the wiring that I don't know about. If they are running a hot cable all the way to the back just for a disconnect switch then it seems like it is less safe than not having a disconnect.
With a battery up front and no disconnect switch there isn't a lot of hot cable. For my car I'm going to use a Ford type solenoid so the starter cable is only hot while cranking. So the only hot line when the key is off is the BATT feed to the fuse panel under the dash. There is some Solid State disconnects now that seem pretty neat. You would have the actual disconnect up front with just some small wires running to the switch in the back. Like this one from Motion RaceWorks. https://www.motionraceworks.com/store/p841/BatteryKillSwitchKitI do not know about NHRA legality though since it is not a mechanical disconnect.
68 Barracuda Formula S 340
[Re: AndyF]
#2482831
04/15/18 12:25 AM
04/15/18 12:25 AM
Posts: 1,134 OHIO THE HEART OF IT ALL
64hemi330sedan
With a battery up front and no disconnect switch there isn't a lot of hot cable. For my car I'm going to use a Ford type solenoid so the starter cable is only hot while cranking. So the only hot line when the key is off is the BATT feed to the fuse panel under the dash. i don't have the wiring diagram handy to post. but there is a simple way to use a switch at the rear using ten gauge and smaller wire.. it just controls the relay mounted in the front. it has to be a snow plow constant power style relay.
[Re: nss guy]
#2482841
04/15/18 12:40 AM
04/15/18 12:40 AM
Posts: 43,305 Bend,OR USA
Cab_Burge
Stockers may have a small battery (possible decoy) up front and large capacity or 16volt in trunk to run everything. Been that way for years
[Re: AndyF]
#2482853
04/15/18 01:12 AM
04/15/18 01:12 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
My battery in the rear is only 11lbs....
[Re: AndyF]
#2482918
04/15/18 03:56 AM
04/15/18 03:56 AM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
With a battery up front and no disconnect switch there isn't a lot of hot cable. For my car I'm going to use a Ford type solenoid so the starter cable is only hot while cranking. So the only hot line when the key is off is the BATT feed to the fuse panel under the dash. On a stocker, a battery has to be in stock location, no disconnect is needed. Add a battery in the trunk, disconnect is manditory. I'll be using the 3 lbs lithium in the front ($375) and if I need weight I'll use steel plate and lead where needed.
[Re: hudsonhornet7x]
#2482996
04/15/18 12:12 PM
04/15/18 12:12 PM
cudaman1969
fredericksburg,va
Could any of these lithium batteries be used for a street/strip car? Lot's of street miles, say 3,000 per year. Good question. A friend owns and runs an RV operation, sells these batteries. He has a ex pro mod Stattis (? spelling) with an 800 cu Chevy engine, he has two batteries (3x5x5), one for starting and one to run the electronics. No problems even with his previous Corvette race car whitch had them also. Just saying with the vibration and extreme conditions the race cars had-have, street driving should be a breeze. Might add, he has a bank of these in his trailer to run lights and AC with solar panels on the roof to recharge. I was amazed how well they worked
[Re: AndyF]
#2483012
04/15/18 12:29 PM
04/15/18 12:29 PM
fast68plymouth
So. Burlington, Vt.
On a stocker, a battery has to be in stock location, no disconnect is needed. Add a battery in the trunk, disconnect is manditory. Exactly.
[Re: AndyF]
#2483039
04/15/18 01:04 PM
04/15/18 01:04 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I put mine up front also just for simplicity.
[Re: moparx]
#2483055
04/15/18 01:33 PM
04/15/18 01:33 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
which begs this question. what about the "factory" location[s] on several newer cars with the battery in the trunk or under the rear seat ? disconnect mandatory even though this is a factory location[s] ? Not that its fast but some of the SRT's are... my wife's 2011 Jeep Grand Cherokee has the battery under the front passenger seat
eBay-cdwmotorsports
