Page 1 of 3 1 2 3
Battery under hood for race car #2482719
04/14/18 08:36 PM
04/14/18 08:36 PM
AndyF Offline OP
AndyF  Offline OP
I'm putting the battery under the hood in the Duster since it makes the wiring easier for the EFI system. I think I can also simplify things by getting rid of the master cutoff switch with the battery under the hood. I looked at the rules and for a 10 second car it looks like a master switch is only required if the battery is in the trunk.
I'll be running a half size battery that only weighs 18 lbs so I don't think there will be much of a weight penalty. Seems to me like an easier way to go but most cars I see still have a full size battery in the trunk. Guess we'll just see how it works out. Anyone else running a small battery under the hood in a bracket car?
Re: Battery under hood for race car [Re: AndyF] #2482727
04/14/18 08:49 PM
04/14/18 08:49 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
In NHRA Stock Eliminator the battery must remain in the stock location....... So, there are plenty of surprisingly quick small tire cars running with the battery up front.
Re: Battery under hood for race car [Re: AndyF] #2482728
04/14/18 08:51 PM
04/14/18 08:51 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I see Lithium in the driver compartment all the time now, but yet to see one under the hood.
Re: Battery under hood for race car [Re: fast68plymouth] #2482734
04/14/18 09:08 PM
04/14/18 09:08 PM
AndyF Offline OP
AndyF  Offline OP
I've seen stock eliminator cars with a master disconnect on the rear panel. That seems really nuts to me unless there is something else going on with the wiring that I don't know about. If they are running a hot cable all the way to the back just for a disconnect switch then it seems like it is less safe than not having a disconnect.
With a battery up front and no disconnect switch there isn't a lot of hot cable. For my car I'm going to use a Ford type solenoid so the starter cable is only hot while cranking. So the only hot line when the key is off is the BATT feed to the fuse panel under the dash.
Re: Battery under hood for race car [Re: dthemi] #2482735
04/14/18 09:10 PM
04/14/18 09:10 PM
AndyF Offline OP
AndyF  Offline OP
I haven't seen that. I wouldn't think that NHRA would allow a battery in the driver compartment. Do they put them in a sealed box or under the floor?
Re: Battery under hood for race car [Re: AndyF] #2482759
04/14/18 10:13 PM
04/14/18 10:13 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Stockers may have a small battery (possible decoy) up front and large capacity or 16volt in trunk to run everything.
Re: Battery under hood for race car [Re: AndyF] #2482811
04/14/18 11:56 PM
04/14/18 11:56 PM
A727Tflite Online content
A727Tflite  Online Content
You cannot run a decoy battery up front - but you can add a battery in back. A guy was suspended for doing this in NHRA.
Re: Battery under hood for race car [Re: AndyF] #2482817
04/15/18 12:12 AM
04/15/18 12:12 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
The front battery must be able to start and run the car. Rear battery for ballast, suspension control and keeping the ignition system at a strong 12V.
Re: Battery under hood for race car [Re: AndyF] #2482823
04/15/18 12:20 AM
04/15/18 12:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
There is some Solid State disconnects now that seem pretty neat. You would have the actual disconnect up front with just some small wires running to the switch in the back.
Like this one from Motion RaceWorks.
https://www.motionraceworks.com/store/p841/BatteryKillSwitchKit
I do not know about NHRA legality though since it is not a mechanical disconnect.
68 Barracuda Formula S 340
Re: Battery under hood for race car [Re: AndyF] #2482831
04/15/18 12:25 AM
04/15/18 12:25 AM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
i don't have the wiring diagram handy to post. but there is a simple way to use a switch at the rear using ten gauge and smaller wire.. it just controls the relay mounted in the front. it has to be a snow plow constant power style relay.
Re: Battery under hood for race car [Re: nss guy] #2482841
04/15/18 12:40 AM
04/15/18 12:40 AM
Been that way for years whistling
Re: Battery under hood for race car [Re: AndyF] #2482853
04/15/18 01:12 AM
04/15/18 01:12 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My battery in the rear is only 11lbs....
Re: Battery under hood for race car [Re: AndyF] #2482918
04/15/18 03:56 AM
04/15/18 03:56 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
On a stocker, a battery has to be in stock location, no disconnect is needed. Add a battery in the trunk, disconnect is manditory. I'll be using the 3 lbs lithium in the front ($375) and if I need weight I'll use steel plate and lead where needed.
Re: Battery under hood for race car [Re: AndyF] #2482983
04/15/18 11:48 AM
04/15/18 11:48 AM
USA
hudsonhornet7x Offline
USA
Could any of these lithium batteries be used for a street/strip car? Lot's of street miles, say 3,000 per year.
Re: Battery under hood for race car [Re: hudsonhornet7x] #2482996
04/15/18 12:12 PM
04/15/18 12:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Good question. A friend owns and runs an RV operation, sells these batteries. He has a ex pro mod Stattis (? spelling) with an 800 cu Chevy engine, he has two batteries (3x5x5), one for starting and one to run the electronics. No problems even with his previous Corvette race car whitch had them also. Just saying with the vibration and extreme conditions the race cars had-have, street driving should be a breeze.
Might add, he has a bank of these in his trailer to run lights and AC with solar panels on the roof to recharge. I was amazed how well they worked
Re: Battery under hood for race car [Re: AndyF] #2483007
04/15/18 12:24 PM
04/15/18 12:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Battery at the firewall.
Re: Battery under hood for race car [Re: AndyF] #2483012
04/15/18 12:29 PM
04/15/18 12:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
Exactly.
Re: Battery under hood for race car [Re: cudaman1969] #2483014
04/15/18 12:35 PM
04/15/18 12:35 PM
moparx Offline
moparx  Offline
which begs this question. what about the "factory" location[s] on several newer cars with the battery in the trunk or under the rear seat ? disconnect mandatory even though this is a factory location[s] ?
beer
Re: Battery under hood for race car [Re: AndyF] #2483039
04/15/18 01:04 PM
04/15/18 01:04 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I put mine up front also just for simplicity.
Re: Battery under hood for race car [Re: moparx] #2483055
04/15/18 01:33 PM
04/15/18 01:33 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
beer
Not that its fast but some of the SRT's are... my wife's 2011 Jeep Grand Cherokee has the battery under the front passenger seat
eBay-cdwmotorsports
Page 1 of 3 1 2 3
