Re: Rod Journal Size
[Re: DusterKid]
#2482141
04/13/18 01:30 PM
04/13/18 01:30 PM
Posts: 4,206 New York
polyspheric
New York
Lower journal overlap means slightly weaker crank (still safe). Smaller journal means slightly reduced local oil pressure, which is a function of circumference × engine speed (still safe).
Boffin Emeritus
[Re: DusterKid]
#2482185
04/13/18 02:48 PM
04/13/18 02:48 PM
Posts: 4,457 Washington
madscientist
Washington
Unless you are burning fuel, there is never a reason to use a 2.375 rod throw. 2.20 is plenty big. 2.100 is more than doable most of the time N/A.
[Re: DusterKid]
#2482187
04/13/18 02:49 PM
04/13/18 02:49 PM
madscientist
Washington
BTW, the smaller rod throw also reduces the weight of the rod, the rod bearing and the rod throw.
[Re: DusterKid]
#2482261
04/13/18 06:50 PM
04/13/18 06:50 PM
polyspheric
New York
I agree, late SBC 2.100" is safe with any conventional stroke, but there are fewer rod choices by length than with BBC. Caveat: if the grinding doesn't unmask an oil passage.
Boffin Emeritus
