Valve spring cup size?
#2482077
04/13/18 11:39 AM
04/13/18 11:39 AM
Posts: 1,178 Indy
FlyFish
Indy
My previous motor had a solid roller cam that required my Edelbrock heads to be machined for spring cups to hold the 1.55" springs. I am rebuilding my motor right now with a solid cam that will have springs that are only 1.46" in diameter. My question is, do I need smaller spring cups or no (or some type of locator)?
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Valve spring cup size?
[Re: FlyFish]
#2482374
04/13/18 11:49 PM
04/13/18 11:49 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
You can use spring cups or spring locators. The locators don't have a outer raised ridge, they center on the valve guide
[Re: FlyFish]
#2482505
04/14/18 11:49 AM
04/14/18 11:49 AM
Posts: 4,210 New York
polyspheric
New York
Is all of your inner vs. outer height differential done at the collar now? Some cup/locators have a step for the inner spring, get the same as you have now.
Boffin Emeritus
