Re: LA to Magnum swap
[Re: RapidusMaximus]
#2481636
04/12/18 02:09 PM
04/12/18 02:09 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Thanks, hopefully I'm getting all the pulleys and necessary brackets with the engine, I'm planning on putting some EQ heads on it so I can use an LA intake...I assume balancing is the same on both engines...neutral?
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
#2481920
04/13/18 12:02 AM
04/13/18 12:02 AM
Posts: 8,499 Candler,NC / Myrtle Beach, SC
JDMopar
You will need to find an LA 360 oil pan to put it in your truck. Both 5.2 and 5.9 Magnums require 360 oil pans, no matter if it's going in a car or truck. Keep the flex plate off of the Magnum and use it. I don't think the 5.2 has balancing weights on the flex plate like a 5.9, but it won't hurt to use it if your truck is an automatic. You will have to rat one torque converter bolt hole out, because unlike our old flex plates, the converter holes are symmetrical.
#2482038
04/13/18 10:03 AM
04/13/18 10:03 AM
Posts: 15,487 Florida
scratchnfotraction
keeping fuel injection or going carb? intake needs a magnum bolt pattern.
make sure the later magnum block has the front mount/lugs on the block, they went away later models. IIRC
you want LA timing/pullys/brackets? it all swaps to magnum. alt mount? IIRC a hole maybe missing on end of head for LA mounting. not sure what the fix is here.
need a fuel pump extension kit from Hughes to run a mech FP eccentric on the short nose magnum roller cam behind the LA cover.
FYI..cam bolt/cup washer for magnum is short with no FP eccentric.
FYI.. to run a magnum cover on a LA engine/cam you grind the eccentric 1/2 the thickness and use LA bolt/washer/eccentric ** you clearance the mag cover to LA fp eccentric to fit.
or keep magnum serp belt/accessories PS pump hose end change to fit steer box
FYI..cam change? order up a long nose roller cam for mech FP/LA cover.
you can use a LA valve cove with 5 bolts on magnum head with 10 bolt holes FYI- fel pro has a 5 hole gasket for magnum head and LA cover.
dist. swaps LA to magnum no issues here
LA headers/mannys fit magnum head IIRC you cant use the magnum mannys in the LA/truck
