1972 D100 Dark Green paint code #2481340
04/11/18 11:28 PM
04/11/18 11:28 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Looking to paint the rockers & back of the cab & I don't have the paint code for the truck. It's got no metallic & it is a really fairly dark green. Anyone know of a good place to check out truck paint codes & possibly it's a fleet color?
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: 1972 D100 Dark Green paint code [Re: grancuda] #2481407
04/12/18 01:07 AM
04/12/18 01:07 AM
Grove, OK
hosehead Offline
hosehead  Offline
Grove, OK
I bet it's a fleet color. Super cool color!
63 Plymouth savoy
65 d100
66 dart race project
58 plymouth suburban
Re: 1972 D100 Dark Green paint code [Re: grancuda] #2482331
04/13/18 09:45 PM
04/13/18 09:45 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
MAYBE "BRITE GREEN DT7596" ? Might be too light.
https://www.ebay.com/itm/1972-DODGE-Truck-Color-Chip-Paint-Sample-Brochure-Chart/121113278826?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D44040%26meid%3D2c827d747dce45c4b9d01dc09c4265de%26pid%3D100005%26rk%3D2%26rkt%3D12%26sd%3D122398624150%26itm%3D121113278826&_trksid=p2047675.c100005.m1851
Apparently also spelled "BRIGHT GREEN"
https://www.ebay.com/itm/1972-DODGE-TRUCKS-VANS-PICKUPS-72-PAINT-CHIPS-RINSHED-MASON-4/372255720870?hash=item56ac2b85a6:g:pKUAAOSwo0JWJyTL&vxp=mtr
Facts are stubborn things.
Re: 1972 D100 Dark Green paint code [Re: grancuda] #2482366
04/13/18 11:42 PM
04/13/18 11:42 PM
scratchnfotraction Offline
you might check under vent cowl for metal data plate riveted to top of firewall on pass side. should have all the codes.
you might look at 77-78 dodge dark forest green...it is very close to what you have on there.
my 85 is a dark green like that but has gold metal flake and was a 2 yr only color option...very $$$ now days.
Re: 1972 D100 Dark Green paint code [Re: grancuda] #2482468
04/14/18 09:56 AM
04/14/18 09:56 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
I've never seen a tag with a paint code on any truck. The only paint codes were on the sticker on the bottom of the hood. I don't know what year they started using those. 71s didn't have them.
The pillars look to be a light green which may be the original color, meaning the other color may have been painted later and could be anything.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 1972 D100 Dark Green paint code [Re: Soopernaut] #2482479
04/14/18 10:56 AM
04/14/18 10:56 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
The cab is from a cleaner truck, that's what I'm wanting to paint to match the darker green, the pillars, rockers & back of cab. The dark green was original, the vin decal is still intact & you can see it's never been taped off.
It may be that brite green.
2021 Toyota Supra
Re: 1972 D100 Dark Green paint code [Re: grancuda] #2483159
04/15/18 05:10 PM
04/15/18 05:10 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
There was a Bright Green in 71 on the Dodge Dude that looks similar to the chip, however it doesn't look like the Dark Green in the pictures. They could have changed the colors for 72. There was also a Pine Green which is pretty dark. In 73 there was Dark Green DT 7682 that looks like a possible match.
