Re: Questions/opinions on an early 5.7 block build
[Re: RTSrunner]
#2473708
03/29/18 07:25 AM
03/29/18 07:25 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Personally I say leave the 6.1 heads to the SRT* resto guys, get a set of Eagles, Hit E-bay there always listed. some great deals on reman's or low mileage heads. The stock 5.7 crank is not a bad piece under 600HP,6500RPM.Stock rods are also ok under 500HP, the stock pistons for the pre Eagle are F--King junk.
Great Combo , Comp XFI268 or XFI273 cam, DSS 6500X or 6510X pistons(difference is .945 VS .927 wrist pin) they are a -5CC piston, yields about 10.5 with Eagle heads. A 6.1 Crank if you have to have a forged crank. as for rods that your choice, so many out there now, every one has a brand that has worked well for them. Arrow(prefix) intake or OCP intake (with the 268 cam). That's my $02 worth
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: RTSrunner]
#2473715
03/29/18 08:08 AM
03/29/18 08:08 AM
ric3xrt
Trumbauersville PA
Also let me throw this in to the mix, the stock Valve springs on the Eagles, will handle both of those Comp cams or you could use a stock 6.1 cam.
[Re: ric3xrt]
#2473784
03/29/18 12:31 PM
03/29/18 12:31 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Great Combo , Comp XFI268 or XFI273 cam, DSS 6500X or 6510X pistons(difference is .945 VS .927 wrist pin) they are a -5CC piston, yields about 10.5 with Eagle heads. A 6.1 Crank if you have to have a forged crank. as for rods that your choice, so many out there now, every one has a brand that has worked well for them. Arrow(prefix) intake or OCP intake (with the 268 cam). That's my $02 worth Have you used the dss pistons? I saw they make them in 3.917 and why I was interested in them... hate to bore a block for pistons when it doesn't need it. Was trying to find a combo of pitons/rods close enough not to have to get it balanced.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: RTSrunner]
#2473832
03/29/18 02:33 PM
03/29/18 02:33 PM
ric3xrt
Trumbauersville PA
Twice in G3s and a few times in LS builds, Ford guys have loved them for a while now. They match sets well, Both builds were .04 over bore with .927 wrist pin ,stock stroke 5.7s. Both engines were balanced. I haven't used them in a "drop in" build.
[Re: RTSrunner]
#2475440
04/01/18 04:15 PM
04/01/18 04:15 PM
ric3xrt
Trumbauersville PA
Bolt pattern yes, shape no, Eagles,6.1s and Apaches are the same port opening,03-08 5.7s are a smaller shape.
[Re: ric3xrt]
#2475513
04/01/18 06:55 PM
04/01/18 06:55 PM
Silver70
Rust Belt, SW PA
Twice in G3s and a few times in LS builds, Ford guys have loved them for a while now. They match sets well, Both builds were .04 over bore with .927 wrist pin ,stock stroke 5.7s. Both engines were balanced. I haven't used them in a "drop in" build. I looked them up and looked to be big in the ford world, some ls guys use them, but your the first I saw mention them in a hemi. I keep trying to find some drop in combo like modernhemi sells that won't require balancing, but no luck... rods are heavier, pistons lighter, but no match yet or even close. If I'm going to pay 1600 for rods/pistons, I'm spending another 600 or so so and getting a balances stroker assembly.
[Re: RTSrunner]
#2480364
04/10/18 09:20 AM
04/10/18 09:20 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
Kinda doing something similar. I have a 03 5.7 Block and cast crank and eagle heads. Not wanting to do overkill on the Pistons and Rods without spending a fortune, Looking at doing 09 and up VVT rods and pistons and do a rebalance because the VVT pistons are a different weight, but the advantage is they are stronger than the early pistons and rods and have the lower compression ratio...The DSS pistons have me thinking, if I was to invest in a steel crank and over 500 hp , I might go that route. The challenge is to find a used set that havent been damaged from improper removal
[Re: RTSrunner]
#2480572
04/10/18 04:43 PM
04/10/18 04:43 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I have heard they are they are all the same but that is wrong, the early 5.7 had puny rods that break frequently in stock well taken care of motors. The eagle 5.7 rod is slightly better, not sure when the switch was but somewhere in the last few years (between 11 and 15) the eagle rod is now full floating but was not at first, the 6.4 apache rods are a ton beefier and the ones I have seen are all full floating. The full floating rods have bronze bushings. I have not compared a BGE 6.4, 6.1 or hellcat rod side by side to the others to tell you what you are getting, I would assume the hellcat and BGE are at least as good as the apache, and have heard from several people who should know that the 6.1 rod is the same as the early 5.7 but full floating.
[Re: johnscudashop]
#2480582
04/10/18 04:58 PM
04/10/18 04:58 PM
Silver70
Rust Belt, SW PA
Kinda doing something similar. I have a 03 5.7 Block and cast crank and eagle heads. Not wanting to do overkill on the Pistons and Rods without spending a fortune, Looking at doing 09 and up VVT rods and pistons and do a rebalance because the VVT pistons are heavier, but the advantage is they are stronger than the early pistons and rods and have the lower compression ratio...The DSS pistons have me thinking, if I was to invest in a steel crank and over 500 hp , I might go that route. The challenge is to find a used set that havent been damaged from improper removal I used a set of eagle piston/rods in my 04 rams 5.7... not a high hp engine, but no vibration at all.
[Re: Silver70]
#2480715
04/10/18 08:50 PM
04/10/18 08:50 PM
johnscudashop
Mrytle Beach SC
Kinda doing something similar. I have a 03 5.7 Block and cast crank and eagle heads. Not wanting to do overkill on the Pistons and Rods without spending a fortune, Looking at doing 09 and up VVT rods and pistons and do a rebalance because the VVT pistons are heavier, but the advantage is they are stronger than the early pistons and rods and have the lower compression ratio...The DSS pistons have me thinking, if I was to invest in a steel crank and over 500 hp , I might go that route. The challenge is to find a used set that havent been damaged from improper removal I used a set of eagle piston/rods in my 04 rams 5.7... not a high hp engine, but no vibration at all. I will know in a few days, I just ordered a set of 09 pistons and rods. I will weigh them. Im thinking the Piston might be lighter. Silver70 What was your specs.? Im not planning a Hi HP build either.
[Re: RTSrunner]
#2480954
04/11/18 09:59 AM
04/11/18 09:59 AM
ric3xrt
Trumbauersville PA
6.4s are the better rod, they are 6.2 Length,.945 wrist pin, the 6.1 rods are 6.242 with a .984 wrist pin, both are Forged Powder metal(what ever that is) ,
*******I'm not 100% on this but I believe forged crank Eagle 5.7s(pursuit and 2500/3500 trucks) starting in 2014 have full floating pins , and the STD passenger car and 1500 series trucks are still pressed till 2016 Or Eagle engines with 3 bolt tone wheel are pressed and 4 bolt tone wheel are full floating. AGAIN I'M NOT 100% sure
[Re: RTSrunner]
#2481197
04/11/18 06:02 PM
04/11/18 06:02 PM
Silver70
Rust Belt, SW PA
Good link with comparisons to early and eagle stuff: 5.7 hemi rebuilders Not really sure how much that part on the strap helps... all the ones I've seen break were on the upper beam part.
[Re: johnscudashop]
#2483424
04/16/18 01:35 AM
04/16/18 01:35 AM
Silver70
Rust Belt, SW PA
A update on the weights of the VVT vrs Non VVT rod and pistons , Minus bearing but rings and piston pins, its 303.3 grams for Non VVT Piston rod assembly and 331.7 grams for VVT, quite a difference . Looking to do a balance on the crank I think you got those numbers wrong... just a stock piston weighs more than 3xx grams. A non eagle rod is around 600. The early piston with pin and rings connected to a stock rod with bolts no bearings, I get about 1205 grams.
