Re: Holley HP EFI Coil Near Plug Spark Plug Gap
[Re: lockjaw-express]
#2479994
04/09/18 02:38 PM
04/09/18 02:38 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I would recommend .028 to .030. Inductive spark and CD spark have to be looked at differently. With inductive spark, the power that doesn’t get used during spark initiation gets discharged in duration.
[Re: TRENDZ]
#2480011
04/09/18 03:11 PM
04/09/18 03:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Rick.. quick question.. what was the name of the holley that I can ask a question thanks.. this is a new puter and I didnt transfer all that stuff thanks
#2480013
04/09/18 03:13 PM
04/09/18 03:13 PM
TRENDZ
Milwaukee WI
Im not understanding your question. I think some words are missing😯
[Re: TRENDZ]
#2480019
04/09/18 03:21 PM
04/09/18 03:21 PM
MR_P_BODY
The Holley site on line that has the one guy that answers most of the EFI questions.. you have been on that site many times.. if you have a problem he usually knows of it thanks
[Re: TRENDZ]
#2480028
04/09/18 03:25 PM
04/09/18 03:25 PM
MR_P_BODY
I dont know the guys name but I want to ask something on the HP unit thanks
#2480031
04/09/18 03:27 PM
04/09/18 03:27 PM
TRENDZ
Milwaukee WI
Danny is the guy that handles most of the questions there. Ijust posted there this morning regarding a post by andyf.
#2480096
04/09/18 05:38 PM
04/09/18 05:38 PM
TRENDZ
Milwaukee WI
The smart coils are inductive. Typical high hp engines using them set plug gap @.018- .022. Spark duration is the benefit.
[Re: TRENDZ]
#2480189
04/09/18 09:42 PM
04/09/18 09:42 PM
Posts: 31,060 Oregon
AndyF
I would recommend .028 to .030. Inductive spark and CD spark have to be looked at differently. With inductive spark, the power that doesn’t get used during spark initiation gets discharged in duration. I haven't looked at this issue much but it seems like the factory uses some fairly wide plug gaps on the newer CNP engines. In the range of 0.040 or so on a few engines that I looked at. Maybe it all depends on the engine and the ignition system?
#2480202
04/09/18 10:12 PM
04/09/18 10:12 PM
TRENDZ
Milwaukee WI
No just the opposite. The CDI is the short duration, high energy start. The inductive sparkis the long duration trail. This is why MSD has multiple sparks below 3000 rpm. The short duration CDI spark would not burn up themixture fully at low rpms.
As far as plug gap, you can run it wide... but you end up with a much shorter spark duration doing so. The wider the gap, the more you stress the coil/ wires/ plugs. The Ign1 coils are capable of burning holes through some spark plug insulators. Much better to take it easy on the hard parts and turn the energy into duration.
