Seat belt questions #2477048
04/03/18 09:40 PM
04/03/18 09:40 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'm trying to put a nice set of seat belts together for my Dart using belts from three different sets of belts I have. One of the questions I have is, is it possible to remove the seat belts from the retractors for the front seats without destroying the plastic enclosure? I have a couple that have real nice belts and buckles but the plastic enclosures are not very nice and I have a couple of others that have real nice enclosures but rusty buckles. So I would like to combine them if I can get the belts out of them. Another question I have is regarding the bolts. I have one complete set of belts that had all of the bolts still with them. There are three different lengths of bolts. Is there a particular placement for them depending on length? I know which two bolts are for the shoulder belts so I just need to know where the others for the belts go based on their length. And lastly, where do the approx. 1/2" metal spacers and rubber washers go?
Re: Seat belt questions [Re: 440mopar] #2477311
04/04/18 11:29 AM
04/04/18 11:29 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Spacers, long bolts and washers are used at locations with more than one belt fastened to the floor. This would be in the two rear locations at the side of the trans hump. It would also be in the front on either side of the trans hump. Short bolts are used where there is only one belt attached.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Seat belt questions [Re: 70gtx440dana] #2477372
04/04/18 01:23 PM
04/04/18 01:23 PM
New York
rarefish Online content
rarefish  Online Content
New York
I don't know if this helps, but here is a picture of the rear seat belts for my 69 Dart, laid out in the position that they are installed.
Re: Seat belt questions [Re: rarefish] #2477984
04/05/18 06:33 PM
04/05/18 06:33 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Thanks guys. Does anyone know about the retractor question I asked? I would really like to swap the belts from one retractor to the other but I don't want to risk ruining the plastic enclosures trying to get the belts out of them if it can't be done.
Re: Seat belt questions [Re: 440mopar] #2478266
04/06/18 12:05 PM
04/06/18 12:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
What do you mean plastic enclosures? Are talking about the rubber boots?
Abe Lincoln
Re: Seat belt questions [Re: dart4forte] #2478304
04/06/18 01:29 PM
04/06/18 01:29 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Mine seem pretty rigid, more like plastic than rubber but yes, that is what I am referring to.
Re: Seat belt questions [Re: 440mopar] #2478346
04/06/18 03:19 PM
04/06/18 03:19 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Do you have a picture of the belts you want to switch? I had rusty buckles on mine and I was able to take the buckles off and switch them with good buckles from another set with bad webbing.
Re: Seat belt questions [Re: 440mopar] #2478423
04/06/18 06:02 PM
04/06/18 06:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
We use a heat gun or hair drier to soften them up a bit. Not too hot to distort them. They usually have two rivets that hold them to the metal. be carefull not to tear the rubber.
Abe Lincoln
Re: Seat belt questions [Re: LTLBEE] #2478981
04/07/18 07:43 PM
04/07/18 07:43 PM
S.E. WI
RichL1967 Offline
RichL1967  Offline
S.E. WI
How did you manage to sew them?
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: Seat belt questions [Re: RichL1967] #2478987
04/07/18 07:54 PM
04/07/18 07:54 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Our belts are sewn using an industrial sewing machine
Abe Lincoln
Re: Seat belt questions [Re: dart4forte] #2479971
04/09/18 01:56 PM
04/09/18 01:56 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Thanks. I will give it a try.
