Re: IT"S HOME!!!!!! 1972 340 4spd Cuda
[Re: UCUDANT]
#247921
08/22/11 11:53 AM
08/22/11 11:53 AM
Posts: 1,300 Washington
19cuda73
Washington
Wow the tail panel is really looking good. Your making great progress. That painted grille blends in really nicely to the rest of the paint. Keep up the good work. Dennis
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: UCUDANT]
#247927
08/28/11 07:18 AM
08/28/11 07:18 AM
Posts: 8,138 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
<img src="/ubbthreads/images/graemlins/laugh.gif" alt="" /> window track is clean...Spent a day or two working on that, it's black on purpose
[Re: UCUDANT]
#247928
08/28/11 07:20 AM
08/28/11 07:20 AM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
it still needs to be trimmed
[Re: UCUDANT]
#247935
09/05/11 05:03 PM
09/05/11 05:03 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
For the next guy out there sweating this out...here's how I did mine. I can tell you no one will do it quite as carefully as you will
There were varying opinions on how to trim and seal the vinyl top at the drip rail/molding. To fold it over or trim it at the edge. I folded it over and sealed/glued it with 3M Super weatherstrip and gasket adhesive... $9.69 at your local parts store I carefully thinned the "doubled over" seam section of the vinyl on the A pillar. The exposed portion you can see is unaffected. I used a razor to thin it down to a single ply and sealed it well.
[Re: UCUDANT]
#247936
09/05/11 05:07 PM
09/05/11 05:07 PM
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I used a razor to apply the 3M adhesive to the underside of the vinyl a few inches at a time and simply held it with my fingers (the rear section is a little more complicated and taping it can help) The razor provides a wide easily controlled surface like the edge of a paint brush, this stuff is thick and dries fast
