Yes you could not get AC w the 4 speed. A Cali carb will definitely run cleaner than the standard one....but w todays gas will it work right? I'm finding more and more that todays gas and carbs are just not compatible. Todays gas is formulated to run in a closed system under 40 or more psi.
The valve cover breather is probably just a better designed oil vapor separator than the 49 state one.
That's not true!
The only single four combo that is not available with AC is a 440 with a manual trans.
For a non-California 1970 340 4 speed WITH or WITHOUT AC you need a 4933S
Heck I might even have one.
