Page 4 of 7 1 2 3 4 5 6 7
Re: It fits...barely [Re: Edge] #2451579
02/14/18 08:30 AM
02/14/18 08:30 AM
Chicago-area Illinois
4mopower Offline
4mopower  Offline
Very cool build!!!! Good luck with it!
Re: It fits...barely [Re: Edge] #2451585
02/14/18 08:45 AM
02/14/18 08:45 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
One of .... the best build on here thumbs
Re: It fits...barely [Re: Edge] #2452232
02/15/18 05:34 PM
02/15/18 05:34 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
What's your timeline for completion?
Very nice indeed.
Re: It fits...barely [Re: Edge] #2452246
02/15/18 06:15 PM
02/15/18 06:15 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Wicked!
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: It fits...barely [Re: Edge] #2452252
02/15/18 06:25 PM
02/15/18 06:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
BASA$$ for sure...
Re: It fits...barely [Re: Al_Alguire] #2452256
02/15/18 06:34 PM
02/15/18 06:34 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Bad to the bone! Dumb question, but is this the same car that was originally built by JCR Chassisworks? Also this thing outta run bottom 6's huh?
Re: It fits...barely [Re: BobR] #2452341
02/15/18 10:45 PM
02/15/18 10:45 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Very nice indeed.
Previous timeline was last summer ! However everything looks very positive for this summers/
76 Duster work in progress
Re: It fits...barely [Re: Forest] #2452351
02/15/18 11:01 PM
02/15/18 11:01 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Different car than the JCR build...that is a very nicely built car for sure. Even considering that this is the same car I will take as a complement. The way I have supercharger pullied we wont be making enough power for bottom sixes and the driver is not ready for that matter. We will try to take it one step at a time.
Re: It fits...barely [Re: Edge] #2452357
02/15/18 11:11 PM
02/15/18 11:11 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
All under the hood up
Bada$$! beer
Re: It fits...barely [Re: Biginchmopar] #2455874
02/22/18 11:16 PM
02/22/18 11:16 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Injectors have been cleaned, flowed and installed ( 210's and 700's), car will idle and run part throttle on the 210's. Fuel lines and oil lines in place. Injector harness is next.
Re: It fits...barely [Re: Edge] #2456670
02/24/18 02:29 PM
02/24/18 02:29 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Line lock and brake lines now installed
Re: It fits...barely [Re: Edge] #2456722
02/24/18 04:00 PM
02/24/18 04:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Getting close. Can't wait for some vids
Re: It fits...barely [Re: FastmOp] #2476463
04/02/18 09:34 PM
04/02/18 09:34 PM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Getting closer !
Vent tank and lines running from burndown tubes to the back of the car. Decided better to have any oil behind the rear wheels and I see more cars with the vent tank in the rear more recently.
Should be firing car up pretty soon !
Re: It fits...barely [Re: Edge] #2476644
04/03/18 08:28 AM
04/03/18 08:28 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
smoke
Re: It fits...barely [Re: Edge] #2477028
04/03/18 08:57 PM
04/03/18 08:57 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
What size tubing are you using for your breathers going to your vent tank? Where did you get it? I'm going to do a similar set-up in my Dart.
Re: It fits...barely [Re: 80arrow] #2477178
04/04/18 01:01 AM
04/04/18 01:01 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
For the vent tubing 1 1/4 inch is specified by NHRA for blown alcohol. NHRA also lists some different types of "approved vent tube". The spec tubing is available on line for example at quartermax for $11 -$20/foot. Spent way too much time looking for alternatives as well 1 1/4 is not a popular ID. Good vibrations sells a simple PVC hose however PVC hose does not stand up well to methanol or oil. The line I used is PVC with a urethane coating on the inside it is actually air seeder hose that I had laying around right under my nose the whole time. In theory it should stand up well but we will see. The urethane coating is intended for reduce wear flowing abrasive material in the hose. You can buy it at most farm supply stores. If I recall this came from the John Deere dealership.
Re: It fits...barely [Re: 80arrow] #2477192
04/04/18 01:19 AM
04/04/18 01:19 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Here are a few more pics of the routing of the vent lines from the burn down tubes, through fire wall and finally along frame rail. My fabricator built a catch can at the low point of the tubing so any oil that accumulates in the lines can be drained from the system.
54386402913__3E59BA26-2527-4444-B9B6-449E6D3B0247.jpg54386401862__2A6CD662-A2AF-4D3B-9185-B832C4C9C69A.jpg54395771381__345CB999-629E-46DB-AA74-D830F5C2423C.JPG
Re: It fits...barely [Re: Edge] #2477193
04/04/18 01:20 AM
04/04/18 01:20 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
I have no idea why some of these photos are flipped when I upload them ?
Re: It fits...barely [Re: Edge] #2478751
04/07/18 10:27 AM
04/07/18 10:27 AM
8
80arrow Offline
80arrow  Offline
Thanks for the info. I'd planned on running -12 from the valve covers to a T, then 1 1/4" from there back to my tank. Looks like I'll have to rethink that, lol. Very nice set-up you have. Can't wait to see how it runs.
Re: It fits...barely [Re: 80arrow] #2479198
04/08/18 01:27 AM
04/08/18 01:27 AM
Alberta Canada
E
Edge Offline OP
Edge  Offline OP
E
Alberta Canada
Fire bottles installed
