Re: Gas tank J-bolts
[Re: gss]
#2474101
03/29/18 11:03 PM
03/29/18 11:03 PM
Posts: 956 Chicago
PurpleBeeper
Chicago
OK, I had a 71 & 73, but never changed the tank on either. A quick search shows 68-74 j-bolts for $18/pair & those look like the ones on my 70. Is there something strange I'm missing?
I guess you could always get some 5/6" or 1/4" hardware store bolts about 6" long, stick them in a vise and bend a 90-degree end near the head and use a hardware store nut. That would work too.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: gss]
#2474180
03/30/18 01:07 AM
03/30/18 01:07 AM
RapidRobert
classic industries may have em
[Re: gss]
#2474827
03/31/18 11:59 AM
03/31/18 11:59 AM
Posts: 956 Chicago
PurpleBeeper
Chicago
Sure thing, no problem. I'd suggest you wire brush the heck out of the threads, or better yet, run a die all the way up the threads before installation. It's always awkward putting a tank up, so anything you can do to make it easier is a good idea. I've even put a piece of plywood on a jack to hold the tank up while I start the nuts on the j-bolts.
[Re: PurpleBeeper]
#2475661
04/01/18 11:19 PM
04/01/18 11:19 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
S I've even put a piece of plywood on a jack to hold the tank up while I start the nuts on the j-bolts. I believe the nuts should be pre-started on the J beforehand. The design is a variant of a "drop-and-go", a common method used in manufacturing facilities. Start the threads of the J-hook with it installed on the strap. Hook the straps into the chassis, hold the tank up and simply hook the hooks. Then tighten.
