Page 2 of 3 1 2 3
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474452
03/30/18 04:36 PM
03/30/18 04:36 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
thanks everyone,UPDATE
the block is now rough bored to .060 and still trying to decide between flat tops and dished pistons for this build. looking hard at the weiand action plus intake and a voodoo cam Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 220/226
Gross Valve Lift (Int/Exh): .475/.494
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
any ideas for the piston choice as the heads have a 80cc combustion chamber.
also what is the best way to stop a 833 four speed from leaking around the tail shaft??
thanks Moparts!!!!
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474456
03/30/18 04:49 PM
03/30/18 04:49 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
As far as the last question. Make sure the mating surfaces are really clean and use a NEW gasket. An old oil soaked gasket will act like a wick and the oil will seep through. I am assuming you are talking where the tail bolts to the main case.
Jeff
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474475
03/30/18 05:32 PM
03/30/18 05:32 PM
Sweet5ltr Offline
Sweet5ltr  Offline
If you're running exhaust manifolds, honestly, you probably can't get better than the original .528 MP solid-lifter camshaft (.502" lift after lash). AndyF did some pretty extensive testing, this camshaft was the best he found for exhaust-manifold applications. The VooDoo series wasn't available at that time, the Lunati camshaft above has less than 240* duration; you should be fine with running manifolds.
On the intake, it's tough for the low-decks. I would personally go with a Holley Street Dominator, wouldn't even consider anything else.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474705
03/31/18 01:37 AM
03/31/18 01:37 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
flat tops fore sure for the pistons !
80 cc and a dished piston you are going to have a Looow compression dog !
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474738
03/31/18 03:16 AM
03/31/18 03:16 AM
Hermiston Oregon
Hermiston Oregon
jeff, yes we're talking about tail shaft housing and he even bought the trick gasket that brewer's sells and a local transmission shop install it when they rebuilt the trany.
Sweet5, we are running TTI coated headers, but we have the airgrabber so intake height is very important.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474739
03/31/18 03:16 AM
03/31/18 03:16 AM
Hermiston Oregon
Hermiston Oregon
and I agree with the flat top pistons.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474740
03/31/18 03:32 AM
03/31/18 03:32 AM
Cab_Burge Online work
Cab_Burge  Online Work
Go to United Machine, KB web site and use the compression ratio calculator to find out exactly what true mechanical compression ratio you will get with flat top pistons with valve reliefs, 80..0 CC heads and a .039 or .042 thick head gasket with a 4.40 bore size scope
You may need a 10 to 12 CC reverse dome, half dish piston to keep the compression under 10.5 to 1 or so for todays pump swill scope
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2474929
03/31/18 03:49 PM
03/31/18 03:49 PM
Hermiston Oregon
Hermiston Oregon
so i did as you said and WOW! a flat top it going to be to much with the stealth heads. I'm looking for a CR of around 9.5-9.7. Might have to find a cam to bleed some compression off.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2475030
03/31/18 07:50 PM
03/31/18 07:50 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
How do you figure
I am running the same kit , .030 over so 432 Stroker from 440 source
Running there Icon flat top pistons with 4cc valve reliefs and 75 cc Edelbrock heads I am at 10.4 compression with a .039 Fel Pro Gasket , pistons where around .020 in the hole after cleaning up the block decks . Yes my quench isn’t perfect but I already had the Edelbrock 75 cc heads prior to the rebuild
I can run 91-93 octane on the street no problems and currently at 36 degrees total timing
Your Stealth Heads are closer to 80 cc
You should bee around 10.1 compression or a little less because those Icon pistons are .025 down in the hole factory block
Are you at zero deck or did your machine shop just clean ?
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2475044
03/31/18 08:12 PM
03/31/18 08:12 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
383 .060 Over 438 Stroker 440 Source Icon Pistons Flat Tops
Bore size 4.310
Stroke 3.75
Rod 6.76
Comp Height 1.320
Below Deck -.025
4cc Valve reliefs
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2475179
04/01/18 02:30 AM
04/01/18 02:30 AM
I should have mentioned to make sure and use + CC for vale reliefs or dished piston volume and - CC for dome pistons on that website blush
Try redoing your calculations using the same info except for adding the + and then change it to the - sign scope twocents up
Re: 1969 RR with a stroker 383 [Re: bee1971] #2475354
04/01/18 01:40 PM
04/01/18 01:40 PM
Hermiston Oregon
Hermiston Oregon
we havent decked the block yet, but the last one of these kits i did was the same but the customer wanted to keep the stock iron exhaust manifolds on the stealth heads with a rather large cam and has a bit of over heating problem during a summer where we had many triple digits days.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2475355
04/01/18 01:41 PM
04/01/18 01:41 PM
Hermiston Oregon
Hermiston Oregon
also we used the flat tops zero decked the block
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2475790
04/02/18 01:20 AM
04/02/18 01:20 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Does the driveshaft have a yoke with a groove worn in it?
I want my fair share
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2476613
04/03/18 02:16 AM
04/03/18 02:16 AM
Hermiston Oregon
Hermiston Oregon
Anybody used the Mopar performance aluminum dual plane intake pn P4529117
It has an rpm range of idle to 5800?
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2476618
04/03/18 02:27 AM
04/03/18 02:27 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
I have one on my 451 , Ram Charger set up. Has tremendous low end and pull to 6k rather quickly.Im shure a performer RPM would work better but will not fit the hood .
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2477757
04/05/18 09:26 AM
04/05/18 09:26 AM
Hermiston Oregon
Hermiston Oregon
Very nice on the Weiand but it might be to tall for the airgrabber.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2477758
04/05/18 09:28 AM
04/05/18 09:28 AM
Hermiston Oregon
Hermiston Oregon
Sweet, that’s what I wanted to hear, now I just have to find one.
Anybody? P4529117 intake for sale, I will post up in the right area.
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2477759
04/05/18 09:29 AM
04/05/18 09:29 AM
Hermiston Oregon
Hermiston Oregon
What heads are you running on your 451?
Re: 1969 RR with a stroker 383 [Re: mopar_leaner] #2480336
04/10/18 02:37 AM
04/10/18 02:37 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
Eddy RPM OOTB
Page 2 of 3 1 2 3
