Duster rear 1/4 window question??? #247377
03/08/09 09:39 PM
03/08/09 09:39 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Completly took apart my rear 1/4 windows to replace the seals,Just ordered window seals but do not know what to use on the outside of frame when i put them back into car--Thanks for the help guys--Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Duster rear 1/4 window question??? [Re: swifter] #247378
03/08/09 10:51 PM
03/08/09 10:51 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Since there was foam from the factory, I replaced it with 3/8" thick 1/2" wide high density "Marine & Automotive" weatherstrip tape that I found at Lowes in the HVAC section. Has adhesive on one side, black. Worked really well.
M-D Specialty #06619
You'll need thick strip caulk at the bottom to seal between the window frame and quarter panel. Glass guys have it.
