E body upper control arm bushings
#2450309
02/11/18 10:00 PM
02/11/18 10:00 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I'm going to replace the upper arm bushings for more caster. What is the proper sequence of removing them. Do I need to release the torsion bar tension?
11B40
Re: E body upper control arm bushings
[Re: boydsdodge]
#2450339
02/11/18 10:37 PM
02/11/18 10:37 PM
JonC
Millinocket, Maine
Order two sets of Moog upper Control Arm bushings Part Number K7103
I already have them, just getting around to replacing them.
11B40
[Re: boydsdodge]
#2450386
02/11/18 11:29 PM
02/11/18 11:29 PM
Posts: 5,363 Rancho Cordova, California (Sa...
hemi71x
Yes you have to release the torsion bar tension. Just put your floor jack under the ball joint in the lower control arm, and put some pumps of the jack to put some tension on the suspension. Then just smack the upper ball joint loose, by any method of your choosing. Remove upper control arm.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#2450401
02/11/18 11:39 PM
02/11/18 11:39 PM
JonC
Millinocket, Maine
Yes you have to release the torsion bar tension. Just put your floor jack under the ball joint in the lower control arm, and put some pumps of the jack to put some tension on the suspension. Then just smack the upper ball joint loose, by any method of your choosing. Remove upper control arm. I can do this, I have it on a lift but have an under hoist safety stand I can use. Thanks
11B40
[Re: JonC]
#2450423
02/12/18 12:14 AM
02/12/18 12:14 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What does the service manual say? Don't have one. Why not? They are free. http://www.mymopar.com/index.php?pid=109
[Re: JonC]
#2450585
02/12/18 11:23 AM
02/12/18 11:23 AM
Posts: 4,744 Florida
BDW
[Re: JonC]
#2450616
02/12/18 12:48 PM
02/12/18 12:48 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I agree noi need to touch Tbars.Just jack stand under lower and remove upper.The moog offsets have to be installed opposite of directions that comes with them.Rocky
Chrysler Firepower
[Re: JonC]
#2450618
02/12/18 12:53 PM
02/12/18 12:53 PM
therocks
Niles , Ohio
Chrysler Firepower
[Re: therocks]
#2450642
02/12/18 01:29 PM
02/12/18 01:29 PM
Supercuda
About to go away
About to go away
up yours
The moog offsets have to be installed opposite of directions that comes with them.Rocky No. Use CNXT's instructions, which are NOT opposite of Moog's instructions.
[Re: Supercuda]
#2450649
02/12/18 01:43 PM
02/12/18 01:43 PM
Posts: 2,253 New York
rarefish
New York
The moog offsets have to be installed opposite of directions that comes with them.Rocky No. Use CNXT's instructions, which are NOT opposite of Moog's instructions. What are CNXT's instructions? I'm not familiar with them.
[Re: rarefish]
#2450656
02/12/18 02:04 PM
02/12/18 02:04 PM
Supercuda
About to go away
About to go away
up yours
The moog offsets have to be installed opposite of directions that comes with them.Rocky No. Use CNXT's instructions, which are NOT opposite of Moog's instructions. What are CNXT's instructions? I'm not familiar with them. Look up 5 posts, not counting this one
[Re: Supercuda]
#2450667
02/12/18 02:17 PM
02/12/18 02:17 PM
rarefish
New York
The moog offsets have to be installed opposite of directions that comes with them.Rocky No. Use CNXT's instructions, which are NOT opposite of Moog's instructions. What are CNXT's instructions? I'm not familiar with them. Look up 5 posts, not counting this one Thanks... That was the instruction I used when I installed them in my 68 Charger some years back.
[Re: Sixpak]
#2451452
02/13/18 11:29 PM
02/13/18 11:29 PM
JonC
Millinocket, Maine
Be aware that those K7103 bushings, installed in an e-body, may reduce your adjustability. I had the exact same set up and found I could not rotate the alignment cams a full 360 degrees. I found that the edges of the upper control arms hit the fenderwell or control arm frame between 2 o'clock and 5 o'clock position on the cam. And I found the adjustment nuts for the bolts really had to be wailed on to keep the alignment settings in place - so much so that I ended up stripping the threads out of a few nuts. You may also hear all sorts of creaking and groaning from those bushings, due to the more extreme angles you can get with those bushings. I found the press on washers that come with those bushings tended to want to pop right off when I removed those arms with those K7103 bushings. Some aftermarket alignment cam maker offers longer locking nuts (close to an inch long) that would solve the thread issue. The next time I try those offset bushings I am going to run the lower ball joint spacers as well, to see if I can get the alignment numbers I want without having to crank the alignment cams so far that they foul on the fenderwell or control arm mounting frame. Can anyone else comment on this?
11B40
[Re: JonC]
#2473623
03/28/18 11:34 PM
03/28/18 11:34 PM
JonC
Millinocket, Maine
My stock bushings are at the max adjustment according to where the cam on the adjuster is now. I assume I have to install them in such a way that they would give more adjustment in the same direction they are maxed at?
11B40
