Dual point distributor #3438317 IBS 4015C #2471359
03/24/18 02:54 PM
03/24/18 02:54 PM
MoPar Offline OP
MoPar  Offline OP
What did this distributor come from ?
Re: Dual point distributor #3438317 IBS 4015C [Re: MoPar] #2471364
03/24/18 03:06 PM
03/24/18 03:06 PM
A Mopar powered car engine whistling shruggy grin
Re: Dual point distributor #3438317 IBS 4015C [Re: MoPar] #2471369
03/24/18 03:20 PM
03/24/18 03:20 PM
MoPar Offline OP
MoPar  Offline OP
If someone knows what it's application is and approximate value.
Re: Dual point distributor #3438317 IBS 4015C [Re: MoPar] #2471371
03/24/18 03:22 PM
03/24/18 03:22 PM
I just checked my 1967 "Glenns" repair manual & their dist numbers for the most part (no 3's tho) all start with (2) so it would be later than that (1967)
Re: Dual point distributor #3438317 IBS 4015C [Re: MoPar] #2471379
03/24/18 03:41 PM
03/24/18 03:41 PM
CA
crackedback Offline
crackedback  Offline
CA
70 340 4bbl manual trans
Not a 6pk dist.
I might be interested in it if you are selling it.
Usually in the 50-100 range. Most expensive sellers try to sell them for 100+ and they sit around for a long time.
Re: Dual point distributor #3438317 IBS 4015C [Re: MoPar] #2471381
03/24/18 03:49 PM
03/24/18 03:49 PM
MoPar Offline OP
MoPar  Offline OP
Ok, thanks for the feedback.
Re: Dual point distributor #3438317 IBS 4015C [Re: crackedback] #2471404
03/24/18 04:58 PM
03/24/18 04:58 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not a 6pk dist.
Being a Prestolite with the original tag,probably a little more than 50-100 .
Re: Dual point distributor #3438317 IBS 4015C [Re: 62maxwgn] #2471467
03/24/18 07:05 PM
03/24/18 07:05 PM
Not a 6pk dist.
Only to the greedy sellers to restoration want to be work
I think I have more than one of them now shruggy
Re: Dual point distributor #3438317 IBS 4015C [Re: Cab_Burge] #2471560
03/24/18 10:02 PM
03/24/18 10:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Not a 6pk dist.
Come on. If it is complete it's worth $100
Hell I'll buy it $100 just on principal grin
Re: Dual point distributor #3438317 IBS 4015C [Re: Morty426] #2471580
03/24/18 10:50 PM
03/24/18 10:50 PM
Not a 6pk dist.
You ain't got it yet work whistling grin
