Re: indy mod man intake
[Re: rbkt65]
#2471280
03/24/18 11:51 AM
03/24/18 11:51 AM
Posts: 4,206 New York
polyspheric
New York
Can't answer your question, but has anyone done a cylinder-to-cylinder test for mixture distribution? I can't see how the end runners (1, 2, 7, 8) are anywhere near the center runners (3, 4, 5, 6). That giant shoe-box plenum has all the fuel drop-out of a tunnel ram, without the mixture velocity in the runners.
Boffin Emeritus
[Re: 64hemi330sedan]
#2471394
03/24/18 04:24 PM
03/24/18 04:24 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
i sure hope it works. I'm gonna find out here real soon. brand new car and engine. if not i guess i will put the ka-boom! intake back on and take my chances. Let us know how it works, I may get one if it does ok. Thanks
[Re: rbkt65]
#2471443
03/24/18 06:41 PM
03/24/18 06:41 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
They are stock port but you can open open up to max wedge, havent looked at in a couple years . Was too big a plenum for my 440 , even with a approximate 20% reduction of volume using a insert . Did seem to have poor carb signal , had to push a lot of jet in it Drove good on street and made same hp as HP1000 holley on m1 and 1" open spacer . Just soft sixty at track footbraking . Did try 1 and 2" 4 poft spacers but saw no real gain Am aiming to set up on my 505 in the next 2 weeks . Should be better plus i am leaving higher off a transbrake
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2471454
03/24/18 06:52 PM
03/24/18 06:52 PM
Posts: 1,443 central ohio
nss guy
central ohio
i sure hope it works. I'm gonna find out here real soon. brand new car and engine. if not i guess i will put the ka-boom! intake back on and take my chances. Looks great !!
[Re: lewtot184]
#2471522
03/24/18 08:50 PM
03/24/18 08:50 PM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
And yet it is still more effective than most of the readily available alternatives for a Nss legal intake.
[Re: GomangoCuda]
#2471535
03/24/18 09:18 PM
03/24/18 09:18 PM
Posts: 145 NJ
cb1289
NJ
... and fits under most stock hoods
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: rbkt65]
#2471567
03/24/18 10:17 PM
03/24/18 10:17 PM
polyspheric
New York
Based on the pictures I've seen, it looks like the end ports are longer, farther away from the closest venturi. Assuming all 8 bbls. match (throttle + venturi), has anyone tried +1 jets in the end bbls. (front primaries, rear secondaries)?
Boffin Emeritus
[Re: rbkt65]
#2471614
03/25/18 12:40 AM
03/25/18 12:40 AM
tex013
Sydney,Australia
PS , when i asked Indy way back they said i needed more RPM to get the best out if it . I was shifting at 6000 trap 6300 I still only shift at 6000 but trap at 6700 . Leaving at 3500 instead of 2300
Tex
[Re: DoubleD]
#2472390
03/26/18 05:39 PM
03/26/18 05:39 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have the Wilsom Pop offs on my Indy tunnel ram also. Hard to see with everything else going on but they are there.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: lewtot184]
#2472406
03/26/18 06:02 PM
03/26/18 06:02 PM
BradH
about as technological as a crow bar. Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box. I hope people make them work, 'cuz I'm happy I don't have to.
[Re: 66coronet]
#2472446
03/26/18 07:14 PM
03/26/18 07:14 PM
tex013
Sydney,Australia
I have run a modman since 2013 I think.
It works. It will work as a bolt on. Spending time and figuring out what it wants will certainly help. I ran mine out of the box up until last year. We are index racing and I needed to slow down so I didn't care to re invent the wheel.
Last year I decided to try a few things and see what it had in it. My observations.
1. It absolutely likes rpm. When short shifting it will work its way down track and when it gets up above 6600 it will start pulling. 2. It needs more jet than you think it does. Possibly due to less than optimal fuel distribution in the plenum. 3. You will read people talking about plenum fillers or stuffers. Do not bother. Dont decrease the flow, REDIRECT the flow.
Its a good piece and it fits under most hoods. I am now working on a best possible combination for my car. A pair of edelbrock 750s make great mph and et. They do not react as well as my 600s did.
I have not tried staggered jetting as mentioned earlier in the thread. what cubic inches motor size ? couple pics of my insert , hope it also directs air flow out towards ports Tex
[Re: BradH]
#2472461
03/26/18 07:48 PM
03/26/18 07:48 PM
Posts: 31,041 Oregon
AndyF
about as technological as a crow bar. Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box. I hope people make them work, 'cuz I'm happy I don't have to. I talked to a guy who claimed to be the designer of that intake. (He doesn't work at Indy). He said the intake was designed for EFI and that it works really well for dry flow. He didn't think it was a good idea to run carbs on that intake but that is the way Indy sells it.
[Re: rbkt65]
#2472519
03/26/18 10:02 PM
03/26/18 10:02 PM
Posts: 826 Georgia
66coronet
Georgia
Tex
Mine is a 499 SR heads max wedge ports Small flat tappet cam 12.5 to 1 comp
That may help direct flow. I was told at least 1 and 3/4 tall and the width of those outside veins in the floor. Pretty much 4 inches wide. Your shape is a little off also. It needs a flat top then rounded to the downhills. This came from someone who built carburetors and modified intakes on cup cars. I know of another modman modified in a very similar way and it cost a ton to have it done by a high end engine shop.
[Re: 66coronet]
#2472556
03/26/18 11:51 PM
03/26/18 11:51 PM
tex013
Sydney,Australia
66 yes mine is a triangular insert . may or may not be best it is what I have , about 1 1/4" high mine is a 505 , 11.0:1 , 272@050 sft . cnc source heads . I have had this intake for a number of years , just got to try it again . Otherwise 1050 dom on adapter to M1 intake Tex
[Re: moparmitch]
#2472581
03/27/18 12:48 AM
03/27/18 12:48 AM
Posts: 9,841 MI, usa
dvw
MI, usa
Hey Doug,
Can you share the proper starting procedure or is this proprietary? I turn the pumps on and fill the bowls. Pumps off, no need to leave them on if something were to happen. If the temp is 50 degrees or warmer with a cold engine. Pump the throttle 3 times. Wait 30 seconds. One more pump holding the throttle 1/2 open. It should start on the 1st or 2nd revolution. If not wait 30 seconds and crank again. When already warmed up 1 pump wait 15 seconds, 1/2 throttle, then crank. If it's below 50 degrees through a cloth fender cover over the carbs and use the cold start procedure. Doug
[Re: dvw]
#2472686
03/27/18 11:41 AM
03/27/18 11:41 AM
Posts: 145 NJ
cb1289
NJ
Screwed it on with two 750 eddy's,stock jetting,sometimes slightly richer,sometimes slightly leaner, depending on the weather. Car runs great. Hundreds of passes since 2014. 493cu, in. 12.5:1, 3700 lb. Very satisfied with my "crow bar"
62 Dodge Dart Wagon
[Re: AndyF]
#2472757
03/27/18 02:05 PM
03/27/18 02:05 PM
Posts: 3,916 usa
lewtot184
usa
about as technological as a crow bar. Pretty much what I thought the first time I saw one w/o the lid on some years ago. IIRC, my posted comment was along the lines that my daughter (who might have been in 1st grade at the time) could have come up with that design using dull scissors and a cardboard box. I hope people make them work, 'cuz I'm happy I don't have to. I talked to a guy who claimed to be the designer of that intake. (He doesn't work at Indy). He said the intake was designed for EFI and that it works really well for dry flow. He didn't think it was a good idea to run carbs on that intake but that is the way Indy sells it. I believe the EFI thing. those short runners would have a pretty high torque peak, and indy always tells folks to "rev them up" on any of their products. can't be a truly carb friendly intake in my opinion.
