5.7 hemi into 4.7 6 speed truck
#2468617
03/19/18 03:33 PM
03/19/18 03:33 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I just added another truck to my fleet, an 06 6 speed 1500 that has a bad 4.7 and want to swap in a 5.7 any one put one in front of that 6 speed getrag? Is there a big enough cable driven TB to where I can just use the 4.7 computer (with tuning of course) so I don't have to try to fool the 5.7 computer to work with the manual trans?
Re: 5.7 hemi into 4.7 6 speed truck
[Re: HotRodDave]
#2468743
03/19/18 08:10 PM
03/19/18 08:10 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
On HPtuners there was a guy who used the 4.7 pcm to run A 5.7, also on Hemi Truck Club user DakotaJ has also had success using a4.7 pcm. As for the Getrag 6 speed, drive it within reason and it'll survive. My biggest contractor @ the day job his daily driver is a 03 4.7 5speed truck that has a mild 5.7 with a Getrag behind it, 55k miles on the combo.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2469230
03/20/18 04:54 PM
03/20/18 04:54 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Since your in PA I take it you have the same smog laws as me. No cel light = pass. I want to do a 04 Dakota 5.7 using the 4.7 ECM. Matt
[Re: HotRodDave]
#2469238
03/20/18 05:00 PM
03/20/18 05:00 PM
HotRodDave
Kalispell Mt.
I am in montana, no smog check but I don't want lights on the dash.
I have an 04 dakota also that has a 5 speeed I would probably prefer that truck for this project but no motor mounts for it and it would be complicated to fab them and I am not into fab work anyhow, so that ones out of the question for now.
[Re: HotRodDave]
#2469325
03/20/18 07:33 PM
03/20/18 07:33 PM
ric3xrt
Trumbauersville PA
Shane swapped the pcm over to the 05 set up. The pcm was for a stick truck so it doesn't throw any CELs. B&G can convert an auto pcm over to manual to avoid the CEL issue.
[Re: HotRodDave]
#2470418
03/22/18 03:09 PM
03/22/18 03:09 PM
HotRodDave
Kalispell Mt.
forgot the custom oil pan that needs made also
[Re: HotRodDave]
#2474532
03/30/18 08:07 PM
03/30/18 08:07 PM
HotRodDave
Kalispell Mt.
so now a 6.4 just showed up on a pallet at my shop, wonder if the trans will handle that, or even if the clutch will hold it?
[Re: HotRodDave]
#2474669
03/31/18 12:15 AM
03/31/18 12:15 AM
ric3xrt
Trumbauersville PA
I have a lot faith in the 238 trans........not that much faith
