Can Anyone ID This Power Steering Pump 2129623? #2467828
03/17/18 07:22 PM
03/17/18 07:22 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I got this power steering pump with some other Mopar parts and can't find an application for it. The casting number is 2129623. There is also a number 168 s 52 stamped into it. Can anyone help me identify it?
Thanks! MJ
Re: Can Anyone ID This Power Steering Pump 2129623? [Re: moparjohn] #2468622
03/19/18 03:39 PM
03/19/18 03:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Federal or a TRW pump
Re: Can Anyone ID This Power Steering Pump 2129623? [Re: moparjohn] #2470158
03/22/18 12:48 AM
03/22/18 12:48 AM
VA
dragon slayer Offline
VA
Solid shaft would be the .96 TRW pump (Small). Should fit the 4 5/8"ID can.
Re: Can Anyone ID This Power Steering Pump 2129623? [Re: dragon slayer] #2470377
03/22/18 02:15 PM
03/22/18 02:15 PM
N.W. INDIANA
N.W. INDIANA
I saw that solid shaft when I was trying to find out what pump I have.
With the part number 2129623 it's telling me the pump is from around 1962? I have measured the back of the pump and it's right at 4 1/2". So with the seal it would be right at the 4 5/8 you speak of. Now if I can just find out what it was used on? Thanks for the replies!
MJ
