340 Valve Cover Breather Aftermarket #2469396
03/20/18 09:51 PM
03/20/18 09:51 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I may be replacing my air cleaner assembly with a drop base unit. Can anyone tell me what size or give me a breather part number that will fit in the valve cover to replace the original unit?
I like this style but I am open to others. I just don't know what size to order.
Re: 340 Valve Cover Breather Aftermarket [Re: YO7_A66] #2469423
03/20/18 10:50 PM
03/20/18 10:50 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
I have and do use that breather in my valve covers, but they do soften up from heat and can fall out.
Re: 340 Valve Cover Breather Aftermarket [Re: joes68340s] #2469448
03/20/18 11:41 PM
03/20/18 11:41 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you Joe!
Does anyone know the correct grommet size for the stock valve covers? Is it 1.22"? Or can I just measure the existing grommet hole and find one with a snug fit?
Re: 340 Valve Cover Breather Aftermarket [Re: YO7_A66] #2470103
03/21/18 11:17 PM
03/21/18 11:17 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Mine measured 1.00" diameter at the main tube. I will be looking at the breathers with the 1.00" + neck.
