440 Source roller rockers #2469740
03/21/18 03:05 PM
03/21/18 03:05 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Has anyone used 440 Source roller rockers? Have to buy a set and someone had mentioned these to me and I don’t know anyone using them. Have to buy them for Edelbrock heads I have because they require them. Thsnks
Re: 440 Source roller rockers [Re: Shatar4] #2469747
03/21/18 03:21 PM
03/21/18 03:21 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I believe the 440 source roller rockers still use needle bearings on the main shaft which can be bad news. Some have posted stories of the needle bearings letting go sending needles through the engine and trashing the rocker shafts. Other rockers use a bushing instead. Yes I know harland sharps use needle bearings but I believe they are a caged bearing.
Re: 440 Source roller rockers [Re: Shatar4] #2469758
03/21/18 03:34 PM
03/21/18 03:34 PM
crabman173
crabman173
They are not reliable
The best cheap rocker is the Stainless PRW and they leave a LOT to be desired
The studs sent with them should go right in the trash use bolts --and it takes a half a day to get the spacing correct where you have roller near centered over valve tip and push rod not rubbing--they are not great but
they will stay in there and run a while on a street unit
There are NO decent rockers for decent price
The Mancini units which are not needle bearing are great except they have a china grade adjuster that you have to be careful with If these had decent quality adjusters they would be good
Harlands are your best bet but they have soared in price and are for a serious build
Just a damn shame we can't get decent rockers for under $400 a set--shoot ...make that $350
I get wonderful quality for Fords or Chevys for around $235 that will stand race roller pressures
It is a real crime!1
the Mancinis could be the answer if they would up the adjuster quality and to be fair I have not bought a set in a long while so ...maybe they have
Re: 440 Source roller rockers [Re: Shatar4] #2469759
03/21/18 03:34 PM
03/21/18 03:34 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Do not use them.
If it were me I would get Crane or Hughes.
Re: 440 Source roller rockers [Re: Shatar4] #2469761
03/21/18 03:35 PM
03/21/18 03:35 PM
Washington
madscientist Offline
Washington
Call Mike at B3 racing engines and let him help you.
And no, he doesn't pay me, nor do I get kickbacks from him (because if I did, I had enough money to go to some tropical island where there is no internet).
Re: 440 Source roller rockers [Re: Shatar4] #2469782
03/21/18 04:14 PM
03/21/18 04:14 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What heads?
Re: 440 Source roller rockers [Re: BradH] #2469784
03/21/18 04:15 PM
03/21/18 04:15 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Edelbrock RPM 84cc
Re: 440 Source roller rockers [Re: Shatar4] #2469817
03/21/18 05:25 PM
03/21/18 05:25 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I've the stamped HD rockers on my Edelbrock RPM's for 10+years. SSH-44 cam, no problems.
Re: 440 Source roller rockers [Re: Shatar4] #2469888
03/21/18 07:08 PM
03/21/18 07:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Edelbrock RPM 84cc
To bad you missed Todd’s @ Competition Wedge group buy on Harlan Sharp rockers. Use them, enjoy them, and still have something of value to sale.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 440 Source roller rockers [Re: Shatar4] #2469934
03/21/18 07:55 PM
03/21/18 07:55 PM
Nevada
merpar Offline
merpar  Offline
Nevada
They are made of the proper alloy and heat treat. The draw back is the needle bearings. Don't use on anything but low spring pressure street motor.
Re: 440 Source roller rockers [Re: pittsburghracer] #2469946
03/21/18 08:05 PM
03/21/18 08:05 PM
fresno ca
mikeysmopars Offline
fresno ca
Edelbrock RPM 84cc
To bad you missed Todd’s @ Competition Wedge group buy on Harlan Sharp rockers. Use them, enjoy them, and still have something of value twocents to sale.
Best option for the money IMHO.
Not a place to cut corners.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 440 Source roller rockers [Re: Shatar4] #2469960
03/21/18 08:17 PM
03/21/18 08:17 PM
AndyF Offline
AndyF  Offline
Edelbrock heads do not require special rocker arms. You can use factory rocker arms with a mild flat tappet cam. For a fairly mild engine the next step up from factory stuff would be a set of nodular rocker arms. They are harder to find these days but sometimes you can round up a set of Crane or Isky nodulars. Next up from them would probably be the Comp steel rockers or perhaps the Mancini aluminum ones. Hughes makes a decent mid-price set and then you start to pay more for the Harland and T&D and stuff like that.
Re: 440 Source roller rockers [Re: Shatar4] #2470004
03/21/18 09:29 PM
03/21/18 09:29 PM
,Pa.
68dodge Offline
68dodge  Offline
,Pa.
Do not buy them. I had the adjuster bolts break off of 4 of them and they were not to tight. One broke off after valve lash was set with the valve cover off. That was a new set last year.
Re: 440 Source roller rockers [Re: Shatar4] #2470018
03/21/18 09:49 PM
03/21/18 09:49 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I use them on all my wedge builds....Been racing my junk with them since 2012...Tore up some racing. I am learning to leave a little wiggle room with the shims....Other than that...good to go.
Re: 440 Source roller rockers [Re: Shatar4] #2470021
03/21/18 09:51 PM
03/21/18 09:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have since bought a set of T&D's for mine, but out of all the valve train parts that failed on my engine the 440 source rockers still look like new after 4300 HARD miles, oh well they are in the trash now. valve springs 155 seat,390 open
Re: 440 Source roller rockers [Re: Shatar4] #2470045
03/21/18 10:12 PM
03/21/18 10:12 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
The mancini rockers are now made by Harland Sharp. Nice rockers for the price.
Re: 440 Source roller rockers [Re: Dragula] #2470089
03/21/18 11:06 PM
03/21/18 11:06 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I hope your running a fine screen pick up or inline oil filter to catch those needle bearings before they stop your oil pump
1963 Plymouth Max Wedge
1971 Barracuda
Re: 440 Source roller rockers [Re: Biginchmopar] #2470091
03/21/18 11:07 PM
03/21/18 11:07 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yes, Hughes are an awesome rocker.
1971 Barracuda
Re: 440 Source roller rockers [Re: Shatar4] #2470301
03/22/18 12:01 PM
03/22/18 12:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If they all failed, they would not still be sold.
The idea is "will the ones that I buy fail?" and the answer is "we don't know".
Considering the damage (needles loose in the head may break everything, even if they don't reach the sump): how good are your nerves?
Boffin Emeritus
Re: 440 Source roller rockers [Re: polyspheric] #2470326
03/22/18 12:39 PM
03/22/18 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont run BB stuff but if the big problem
seems to be the adjusters you can buy a quality
set of adjusters from a few different places.. as
for the needles I run a screen in the valley
and up the sides so nothing gets past.. I run
TDs on all my junk.. this is just a idea if you
wanted to try it
wave
