Re: Cost to have quarters replaced ? [Re: 340SIX] #246923
03/10/09 09:28 AM
03/10/09 09:28 AM
missouri, USA
moparmojo Offline OP
missouri, USA
I am assuming you are saying to trim around the quarter window to dutchman area, then butt weld in that area. Use the quarters available and trim to fit. Is there any templates for this out there or is this a sort of best guess? It would suck if this area was in bad shape and could not be saved.
Re: Cost to have quarters replaced ? [Re: moparmojo] #246924
03/10/09 10:30 AM
03/10/09 10:30 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I average about 40 hrs each side. In western New York you can bet on replacing the wheelhouses, trunk extensions and more likely than not inner rocker repair. I can't see it being done properly in any less time. OE style panels will take less time than the old junk skins that folks still seem to want to use. The 300 savings on the skins vs. the OE panels gets eaten up real fast at the shop in extra work required.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Cost to have quarters replaced ? [Re: sixpackbee] #246925
03/16/09 06:19 PM
03/16/09 06:19 PM
O
OLD318 Offline
OLD318  Offline
O
Book time to replace a factory quarter panel
on an old mopar is usually 16 hours on a vinyl
top car... 14-15 on a non-vinyl top car.
That would be for one perfect NOS factory
quarter panel on 1 car with no other issues and that does not take into consideration refinish time.
Even in a perfect world, that will almost
never happen..There are always other issues!
1) If the quarter needs to be replaced,
usually the the trunk extension and the
outer wheel house need to be replaced too...
That adds time... figure 8 hours for both
panels...each side... the actual book time
is less than that, but that estimate is with
NOS original factory parts NOT REPROS...
Your now at 24 hours per side...
not including the cost of the quarter panels
the wheel houses or the extensions..
2) If your replacing you trunk extensions the
trunk floor will have to be replaced as well..
Add 8 hours for the trunk floor plus the
cost of the floorpan...again they may want
more time due to repro floor pan...
3) The E-Bodies also have issues with the
rear window cowl (dutchman panel)
add 6-8 hours for that) plus $125.00 for
the panel. (if necessary)
4) the rear tail panel /
lower rear valance may also need to be
replaced. add for that as well...
5) Rear framerails may also be an issue..LOOK
first before having the bodyshop replace this
stuff
Now add additional cost for seam sealer,
epoxy primer, and undercoating...
When finished the body shop should finish off
the The inside (trunk floor) with at least 2 coats of epoxy primer, seam sealer and then paint..The factory did not use clearcoat on a trunk - you don't have to either... $$$$ most people do cuz it looks nice and shiny!
your paying for it! = it's up to you!
The outside (underneath the trunk floor,
the trunk extensions, and the inner wheel houses
should have this done as well
The outside of the quarter panels should have
the EDP still in place...so you can leave that alone for now...
Your easily looking at 80 hours * bodyshop rate
(80*50) = 4000 for labor
parts:
Quarter panels $1000 (500 per side)
outer wheel hous 500 (250 per side)
trunk exten 140 (70 per side)
trunk floor 300
plus shipping
plus materials (seam sealer, epoxy primer etc)..
Your in this for easily $6000
if the shop rate is 45 and hour
maybe $5000...
if you have to do the rear window cowl,
tailpanel or valence - the cost goes up too..
Nothing like an old mopar!
to help a man with a FAT wallet!
FWIW, most body shops will NOT sign up for
this job...(i.e repairing old cars most are
late model collision only)..
DO NOT SIGN UP FOR A TIME & MATERIALS quote
from a body shop...that's a recipe for the poor
house... Most will quote this knowing full well
your not going to sign up for it. This is
pleasant way of saying no thanks! Don't argue
with them, smile and take it somewhere else.
Regardless if this is a convertible or a hardtop, I would take it to a frame shop and make sure the
frame is straight before cutting off any
structural sheet metal.
And yes, quarter panels, and trunk floors are structural panels...
Hope this helps.
Best of luck to you!
Re: Cost to have quarters replaced ? [Re: OLD318] #246926
03/17/09 12:34 AM
03/17/09 12:34 AM
New Castle, In. 47362
dbdcuda Offline
dbdcuda  Offline
I can't help but laugh when I read comments like "do it your self, they're easy" and 5 - 10 hours to replace a quarter panel! I guess if you just want your quarters hacked off and new ones put on over the rusty inner panels, then that shouldn't cost much. If you don't know the difference, why pay the difference. But keep in mind, if you plan on keeping the car, how much more work will be needed when all that crap starts showing up down the road. The fact is, it is very time consuming for a professional to replace quarters properly to where you can't tell they have been replaced and usually you open a can of worms once you've cut them off. I guess it all comes down to how nice do you want it and what's in your budget. By the way, I have replaced dozens of quarters in the past 30 years and I can't say any of them were "easy".
dornautocraft.com
Re: Cost to have quarters replaced ? [Re: dbdcuda] #246927
03/17/09 07:23 AM
03/17/09 07:23 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
I have tackled this issue myself on a 70 GTX.
I have ended up replacing EVERY panel including both rockers and all 4 door posts!!!
I have NEVER done any body work before I started this project.
My mind set was that I needed a hobby so I have remained calm and I have the advantage of a great friend who builds cars for a living letting me do this in his shop under his tutelage.
I have been at it for 9 months and just yesterday finished plug welding drilled spot weld holes to reattach both 1/4's. I average 1 day per week 8 hours working on it. I have MANY more days to go ...more welding at dutchman, and probably a week of nothing but grinding those welds flush THEN getting into the body finish process.
What consumed lots of time was taking two cars apart so I could get one back together and I was lucky to find a donor with parts.
To me, if I had the $$$ 7000 would have been a frickin steal!!!
see my pain at
http://s284.photobucket.com/albums/ll40/DariusCRCKBR/Bodywork%20Pics/
Driving modern convenience in classic beauty
Re: Cost to have quarters replaced ? [Re: OLD318] #246928
03/17/09 08:12 AM
03/17/09 08:12 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Actually the factory didnt use clear coat on the out side of the car either. You need to put some clear on the base, Base isnt meant to be a top coat. You dont however need 4 coats of clear in the trunk. 1 wet coat should be fine.
If your using aftermarket quarters and valance you will run in to fitment issues with the valance. They never fit correctly.
Re: Cost to have quarters replaced ? [Re: OLD318] #246929
03/17/09 09:08 AM
03/17/09 09:08 AM
WI
RestoRick Offline
RestoRick  Offline
WI
Getting a quoted price guarantees nothing.
A quoted price can be a recipe for disaster too... the shop gets backed into a corner when the price isn't enough and then the job gets rushed to keep the lights on or it gets pushed in the back to work on profitable projects.
There's a reason most of the top shelf restoration shops charge time & materials. (And it's not to push the work somewhere else.)
Finding an honest competent shop that knows Mopars is the key IMO.
Rick
Re: Cost to have quarters replaced ? [Re: RestoRick] #246930
03/17/09 10:27 AM
03/17/09 10:27 AM
O
OLD318 Offline
OLD318  Offline
O
Rick
Well, I agree with you on everything you said.
Overall I think the average guy who owns a mopar
which needs substantial body work is in a real
predicament.
They don't know how hard and time consuming it really is to redo these cars given most B and E
bodies need to be completely rebodied from
the rear windshield back.
Meaning quarters, cowl, outer wheelhouses, trunkfloor, extensions rear valance, etc.
plus work on the floorpans, fenders and lower doors etc...
And God save ANY mopar owner that has any frame issues which require a frame machine to pull and straighten it.
I have yet to EVER see a shop that will measure, pull and straigten an old mopar frame.
They will put them on a frame machine
(ala muscle car restorations) to replace sheet
metal to hold the structure in place.
I have never seen any articles in any of the mopar
mags, nor do you see this aspect of restoration
discussed anywhere...
Its amazing almost. You can go to a body shop
which does frame work, look inside and see cars that have literally gone airbourne and wrapped around a tree sitting on frame machines being
mesaured, pulled and straightened.
But ask them to look at your old mopar
where the front is diamond to the right slightly... they'll say
"That's not something we would do."
Only in America...Go figure!
Re: Cost to have quarters replaced ? [Re: OLD318] #246931
03/17/09 11:51 AM
03/17/09 11:51 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
We have straightened many Ford, GM and Mopar muscle car frames since my dad opened the shop in late 1970.
Re: Cost to have quarters replaced ? [Re: elitecustombody] #246932
03/17/09 09:41 PM
03/17/09 09:41 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
not looking in the book,average is about 12-16 hours to replace a quarter,as far as the difference between vert and hard top,I couldn't tell you much other than the obvious upper section where quarter glass goes and further where it wraps around towards the bottom corners of rear glass,so probably extra few hours there, in the end it shouldn't be more than 20 hours per side
Ask the guy who is do the job for the first time. That be me. First off I started with a Goodmark skin. The skin has about 2 hours in trimming before you can think about putting it on the car. There is another 2 hours to cut the quarter off. Yes it can be done quicker but this is a solid car that was in an accident and had the wrong year quarter put on. Figure an hour or two of triming to get a good gap before welding. I must of had the quarter on and off the car 50 times for trimming. Then I got the final gap where I felt comfortable welding it on. I spent 2 hours welding and grinding tonight. There's another 2 hour in welding left. That's 10 hours. There's another 4 hours to do finishing mud. Basically a week of nights and a weekend should get it ready. I was quoted $500 by a local resto shop. If I had to do it again I would do it myself. The job justified the price of me buying a welder. Be patient and keep the metal cool. If you get in a rush you will only create more work.
Re: Cost to have quarters replaced ? [Re: moparpollack] #246933
03/17/09 10:11 PM
03/17/09 10:11 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
I am doing this also at this moment. So far I have worked about 8 hours in removing the quarter. One of my hang ups has been a hack repair job early in the cars life. Instead of spot welds, I am grinding "seams" that were brazed. I did the rear frame rail replacement along with trunk floor first. ( pics below)
All I can say that honestly, anyone that thinks this is a 5 to 10 hour job probably didn't get the car apart enough to even consider doing this job right. When was the last time anyone got a rusty bumper off in 10 minutes, the rear window trim removed in 15 minutes, I spent a couple hours getting the rear window out after getting the trim off. Oh, not to mention the Sunday afternoon I spent just scraping undercoating so I could prepare for the re install. I am all for a fair wage for a good job, but I am gaining some insight as to why a lot of body shops won't do this work. Myself, I am having the time of my life I am reasonably motivated and reasonably talented and this is a big job......
Re: Cost to have quarters replaced ? [Re: belv2vert66] #246934
03/17/09 10:26 PM
03/17/09 10:26 PM
85086
Lil Herman
Lil Herman
85086
I guess I was lucky I didn't have rust. But that adds to the problem. All my inner stucture was clean. I just wire bruched off the dirt and had good metal.
Re: Cost to have quarters replaced ? [Re: belv2vert66] #246935
03/18/09 12:14 AM
03/18/09 12:14 AM
missouri, USA
missouri, USA
I don't doubt this is a tough job. This is the reason I considered farming it out. I also understand the importance of doing a good job. However, I also have to weigh the cost of someone else doing the work. In the end, I just dont think I can swing someone else doing it. Maybe I could afford it somehow, but the likelihood of me making a decision and having it done is a stretch. I think I would rather spend a bit of money, get a welder, learn to do it myself and be proud. Will it be the best, maybe not. If it totally sucks I have the option of having a pro redo it. Hopefully not. I did not realize there was this such a huge price associated with this work. My thoughts were weigh off. But I think with time and patience a regular guy can do it. The car needs it and there really is no moral way I can get around it. If there was, I probably would skip the quarters for now, but they are surely toast.
There was a post a while back on the proper weigh to do this procedure, but I cant find it in the archive. Maybe someone will have it. I think from what I am hearing $5000 sounds like the average.
Re: Cost to have quarters replaced ? [Re: moparmojo] #246936
03/18/09 01:41 AM
03/18/09 01:41 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'll replace all the quarters anyone wants for 5k a pair... much rather do that then sanding.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Cost to have quarters replaced ? [Re: AdamR] #246937
03/27/09 11:22 PM
03/27/09 11:22 PM
Shopping @ HoBo Fright
340SIX Online content
Doc Flappergas's Evil Twin
340SIX  Online Content
I keep waiting for Elite Custom Body to give a price he beat around the bush earler in the thread about how everyone else is charging to much.
I think most agree when quaters are needed the trunk extentions are shot as well and probery a trunk floor.
So Stephan like to hear you cost as compaired to others that have posted
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Cost to have quarters replaced ? [Re: 340SIX] #246938
03/28/09 02:37 PM
03/28/09 02:37 PM
missouri, USA
missouri, USA
Well, just an update. I decided to take a break from the floor pan install and went ahead and took off the rear valance and drop the gas tank and filler tube. Altough the extensions looked good from the top the bottoms were a different story. The driver side was pretty much toast and the other had a decent size whole in it. I pushed on it and sure enough a huge chunk of quarter panel & filler popped out the other side. Gez this car was doped up (filler everywhere). But I will get the last laugh..
