Re: Crank balance question
[Re: 65Dodge440]
#2468906
03/20/18 02:21 AM
03/20/18 02:21 AM
Posts: 4,457 Washington
madscientist
Washington
If it's light it need Mallory metal. If it's heavy I'd turn the counterweights down first and then drill small holes.
You'd have to have a Flintstone style bobweight to have end weights that light.
If they can't turn the counter weights and drill some holes maybe need to start over.
Just reread OP and they want it external. How heavy is the bob weight? To ADD that much weight the bobweight must be 2500 grams. Or more.
Something is wrong
[Re: 65Dodge440]
#2468915
03/20/18 02:51 AM
03/20/18 02:51 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
I have the same crank using with Scat I beam rods and KB744 pistons..it has mallory metal in front and rear counterweights...
that mopar crank is a Scat crank....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: EchoSixMike]
#2468988
03/20/18 10:28 AM
03/20/18 10:28 AM
crabman173
crabman173
Scat made LOTS of cranks that were out a mile for normal bob weights-- That is the deal
[Re: ]
#2469075
03/20/18 12:45 PM
03/20/18 12:45 PM
madscientist
Washington
Scat made LOTS of cranks that were out a mile for normal bob weights-- That is the deal That makes sense then because from the looks of his parts his bobweight isn't abnormally high. Pretty [censored] deal they say it will internal balance and it doesn't have enough mass to do it.
