Collector Gasket ? #246791
03/08/09 11:37 AM
03/08/09 11:37 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Who is using what for header collector gaskets? Can just copper RTV be used? I live in the boonies and have to either drive an hour away or mail order stuff.
Re: Collector Gasket ? [Re: JonC] #246792
03/08/09 11:45 AM
03/08/09 11:45 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
If you want it to last add a gasket.
logan426
Re: Collector Gasket ? [Re: MLR426] #246793
03/08/09 11:50 AM
03/08/09 11:50 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
logan426
What composition?
Re: Collector Gasket ? [Re: JonC] #246794
03/08/09 11:56 AM
03/08/09 11:56 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You can use whatever type of gasket you choose. Adding copper rtv is the best way to make the gasket last.
Re: Collector Gasket ? [Re: Neil] #246795
03/08/09 12:02 PM
03/08/09 12:02 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I have several thicknesses of gasket material, paper type and I have some copper RTV. You think that would be OK?
Re: Collector Gasket ? [Re: JonC] #246796
03/08/09 12:09 PM
03/08/09 12:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should be fine. I have used the copper rtv on the cheap white mr.gasket brand gaskets with good results.
You'll want to go back and check to make sure the bolts are snug after you drive it a few times. I think the heat causes the gaskets to shrink a little and that in turn makes the bolts loose.
Re: Collector Gasket ? [Re: Neil] #246797
03/08/09 12:10 PM
03/08/09 12:10 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Thanks!!
Re: Collector Gasket ? [Re: JonC] #246798
03/08/09 12:11 PM
03/08/09 12:11 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I like the the doubled tapered donut type gaskets. Have yet to have one blow out.
Re: Collector Gasket ? [Re: MoparforLife] #246799
03/08/09 12:18 PM
03/08/09 12:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
On the collectors we use Summits copper gaskets.I have them on the cut outs also.My kid blew out 1 after having them on and off probally 50 times in 7 years.Mine have been off quite a few times in the past 5 years and no leaks.Now on the heads I run Mr Gasket Ultras only.Ive even reused them with no leaks.Rocky
Chrysler Firepower
Re: Collector Gasket ? [Re: therocks] #246800
03/08/09 07:52 PM
03/08/09 07:52 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I will order some good ones, just needed something to get me by. The snow is melting fairly quick now, maybe another month and I'll be on the road again.
Re: Collector Gasket ? [Re: JonC] #246801
03/08/09 08:08 PM
03/08/09 08:08 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Get the 1/4 inch aluminum ones they last the longest and can be reused. the copper ones are ok but still way better than the paper ones. Surprisingly I found the aluminum ones at Kragen. The local speed shop ran out of them!
http://shop.oreillyauto.com/ProductDetai...egoryCode=3330C
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
