PCV too small for grommet #2467894
03/17/18 10:43 PM
03/17/18 10:43 PM
Northern Virginia
Moparmaniacc Offline OP
Northern Virginia
It's a repro stock RB engine PCV...I can't remember where I bought it. Just a tiny bit too small for the grommet. This should be easy, which piece to change? thanks
Re: PCV too small for grommet [Re: Moparmaniacc] #2467909
03/17/18 11:22 PM
03/17/18 11:22 PM
You might take it to your parts house & compare it to another one & possibly some RTV sparingly on the PCV OD might tighten it up.
Re: PCV too small for grommet [Re: RapidRobert] #2467923
03/17/18 11:58 PM
03/17/18 11:58 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Which style of PCV valve is it? Three different styles so it would be interesting of the style and if your using the reproduction grommet as well. Thanks for the information.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: PCV too small for grommet [Re: Moparmaniacc] #2467937
03/18/18 12:53 AM
03/18/18 12:53 AM
Northern Virginia
Northern Virginia
It's an off white color, with the words Made in USA in one place and the number 210 in antother place. Gotta get my photobucket hosting working again.
