Re: max comp ratio for 91/93 octane pump gas
[Re: rbkt65]
#2467965
03/18/18 02:25 AM
03/18/18 02:25 AM
Posts: 43,206 Bend,OR USA
Cab_Burge
If you make sure every cylinder has between 10.5 up to 10.7 and you get the correct spark plug, ignition timing and air fuel mixture correct you should do well The next important question is which aluminum heads are you choosing? How much quench also? The compression ratio is only part of the end results along with all the other parts that affect the motors we run on the street today
[Re: Cab_Burge]
#2468108
03/18/18 02:26 PM
03/18/18 02:26 PM
BradH
The compression ratio is only part of the end results along with all the other parts that affect the motors we run on the street today That would have been the best first reply to the OP, IMO.
[Re: rbkt65]
#2468359
03/18/18 11:08 PM
03/18/18 11:08 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
In Australia we have 91,95 and 98 at every pump. You guys dont have 98 ?
1963 Plymouth Max Wedge 1971 Barracuda
[Re: rbkt65]
#2468365
03/18/18 11:18 PM
03/18/18 11:18 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I have run an aluminum headed, 360 with good quench at 11:1 with no problems, it did have a pretty big roller cam though. I have raced it on 91 and 93 with zero difference. I have also run it down the highway on 89 before with no trouble. Lots of variables but that has worked for me.
68 Barracuda Formula S 340
[Re: rbkt65]
#2468483
03/19/18 09:50 AM
03/19/18 09:50 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you have already built a motor with too much compression, i understand water injection systems work great at eliminating detonation Check into that. Some heads really help reduce tendancys to detonate. Double quench chambers like magnum 5.9 heads need less timing, and can run well with more compression than other heads.
[Re: rbkt65]
#2468568
03/19/18 01:37 PM
03/19/18 01:37 PM
Posts: 59 Florida
Sweet5ltr
Dynamic Compression Ratio - this will be a good indicator if you can run on pump fuel.
I run around 9.6:1 cr with Eddy aluminum heads and 32-34* total timing in my 470 low-deck. 259/267 @ .050 / 110 lsa camshaft.
No reason to go big on compression with pump gas, if I'm losing 3% +/- per point, i'm not going to risk detonation and pull timing as a band-aid.
In a street car, we all know the load is variable, if you've ever watched a wideband air/fuel gauge, you can see how quickly an engine can go from rich to lean, varying on throttle position, transitions, and multiple other factors; it's nearly impossible to tune a carb to be perfect in all conditions year-round. In a race car, the load is somewhat constant, simply tune for WOT - 12.5:1 +/- AFR. Make it fat, lean it out.
Detonation destroys engines, if it's not a bracket / race car, stay on the lesser end of the compression spectrum and run as much timing as needed.
1969 Plymouth Road Runner (440 w/ Boost! RIP) now a low-deck 470 with hotchkis suspension, nascar boom tube exhaust, & big brakes.
[Re: Sweet5ltr]
#2468628
03/19/18 04:01 PM
03/19/18 04:01 PM
Posts: 3,916 usa
lewtot184
usa
Detonation destroys engines, if it's not a bracket / race car, stay on the lesser end of the compression spectrum and run as much timing as needed. makes sense approach.
[Re: rbkt65]
#2468662
03/19/18 05:14 PM
03/19/18 05:14 PM
Posts: 4,206 New York
polyspheric
New York
High static CR increases: 1. torque, especially part throttle 2. mileage 3. vacuum
Boffin Emeritus
[Re: Dave Hall]
#2468937
03/20/18 04:06 AM
03/20/18 04:06 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You can buy 100 unleaded here at the pump. Just have to know where to go. What it cost there? I just paid a bit over $8/gallon for 100 unleaded here in Denver. There are a large number of variables that determine what octane fuel an engine will use. Tell us more info, what engine, what heads, what cam or application, what vehicle, transmission, stall speed, gear ratio, ect. Someone likely has already built something like you are asking about.
