stroker kit #2466981
03/15/18 05:21 PM
03/15/18 05:21 PM
NY
moparmatt0 Offline OP
NY
I have a kieth black block with b-1 original heads currently is a 499 looking for more displacement who has the best deal will be used for drag race only thanks for any help Matt.
Re: stroker kit [Re: moparmatt0] #2467003
03/15/18 06:09 PM
03/15/18 06:09 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
440Source
Re: stroker kit [Re: moparmatt0] #2467007
03/15/18 06:16 PM
03/15/18 06:16 PM
an8sec70cuda Offline
A KB block w/ B1 heads is gonna be a pretty serious piece. I'd put some quality, higher end, parts in that build. A good engine shop could put together a "kit" for you, but I doubt you'll find any online mail order kit like that. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: stroker kit [Re: moparmatt0] #2467060
03/15/18 08:33 PM
03/15/18 08:33 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I worked with Chip at Ohio Crank and am very happy so far with my 451. I would give them a call and see what stroke/rod combos they have available (way more than what's listed on their website). I was able to pick the Piston (Diamond with 1 free spec change), the rings (gapless) and the bearings I wanted without issue. He worked with diamond to find a Chevy piston that saved me from having to deck them for my compression height. Paid for the kit, had it a few days later.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: stroker kit [Re: moparmatt0] #2467087
03/15/18 09:34 PM
03/15/18 09:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You won't find a kit. B1 heads have a different valve angle than say Indy's or Trick Flow, so there are no shelf pistons available. Plus, the amount of power that the B1 heads can produce are more than what most "Economic" rotating assemblies can handle. You are going to want some good parts in that combo.
[image][/image]
Re: stroker kit [Re: moparmatt0] #2467138
03/15/18 11:31 PM
03/15/18 11:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I would call Koffels they might have the parts on the shelf for that combo twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: stroker kit [Re: moparmatt0] #2467164
03/16/18 12:28 AM
03/16/18 12:28 AM
What size is the current bore?
On your deal I would look at buying and using a 4.25 billet steel center counter weighted crankshaft(check with Ohio Crankshaft for a good deal on them up) with either BB Chevy 2.2 or large journal SB Chevy 2.100 rod journal sizes and good set of rods, steel or aluminum and then the best custom pistosn you can get with .043,.043, 1/16 oil rings set up for a vacuum pump, no gapless rings tsk
The B1 heads and top end parts you have now will rev to 8500 RPM pretty easily with all the other good proper parts to do that, if your willing to do that then buy the good parts now while every thing is still in good shape twocents work
I have a new high nickel cast iron 4.500 bore size Koleno block and a set of B1-MC heads with Ti intake valves that I am planning on building a 555 C.I. bracket motor with a old used Sonny Bryant top fuel forged steel fully counter weight 4.375 stroke crankshaft with BB Chevy rod journal sizes and all new parts to achieve near 1000 HP on E85 fuel with a single large dominator carb., or maybe two 1050 CFM Dominator carbs on a sheet metal tunnel ram on E85 if needed luck work
Re: stroker kit [Re: Stanton] #2467191
03/16/18 02:03 AM
03/16/18 02:03 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Originally Posted By Stanton
440Source
NO!
Just bite the bullet on price and get real American parts. Bryant, Callies, Crower, ect...
JE, Ross, Diamond and ICON ca get you the right piston.
Re: stroker kit [Re: Biginchmopar] #2467192
03/16/18 02:06 AM
03/16/18 02:06 AM
Carson City, Nevada
Carson City, Nevada
Another option on rods and pistons is BME. I can get you a pretty good deal on parts from BME.
Still not cheap but some of the best parts around.
Re: stroker kit [Re: Biginchmopar] #2467277
03/16/18 12:09 PM
03/16/18 12:09 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
440Source
NO!
iagree. This for sure!!!
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: stroker kit [Re: Biginchmopar] #2467510
03/16/18 09:36 PM
03/16/18 09:36 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
And I'm sure Diamond or any major piston manufacturer has, or has the ability to create, these valve angle pockets. He won't be the first to run B1s I'm sure.
440Source
NO!
440 Source has trouble centering a crank seal in a timing chain cover...so I don't trust them with rotating assemblies in the slightest.
Re: stroker kit [Re: A39Coronet] #2467520
03/16/18 10:00 PM
03/16/18 10:00 PM
sgcuda Offline
sgcuda  Offline
The OP asked about a stroker kit. The point is that there are no "in stock" pistons that will work with a B1 cylinder head. Any company can cut some pistons. But he shouldn't trust a salesman looking to make an end of the week quota that tells him something like they are "Universal Fit" or "They Fit All Wedge Heads".
Re: stroker kit [Re: sgcuda] #2467532
03/16/18 10:24 PM
03/16/18 10:24 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
When you build combos with higher cubic inches there are so many ways to get where you are going. My 572 combo I put together in 2009 had a set of Indy pistons cut for 440-1 heads. I then had them cut for B1’s also. It had a stock length 440 rod in it. The 572 I am building now has a 7.150 rod in it. I see lots of used pistons out there but you won’t find many on the shelf. It doesn’t take that long to get a set of custom pistons made
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: stroker kit [Re: sgcuda] #2467534
03/16/18 10:26 PM
03/16/18 10:26 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
So then OP shouldn't order a stroker kit through a Jegs or Summit hotline.
If he calls Ohio Crank, they will piece together a kit with what he needs, by working with trusted and proven vendors. I doubt Diamond or any major dealer is going to risk their reputation to meet an imaginary quota.
Diamond gives you one profile modification for free. It's not uncommon to have to get non-standard pistons. These are cylindrical slugs with relief cuts...not a space shuttle engine. You said it yourself..."any company can cut some pistons".
Re: stroker kit [Re: A39Coronet] #2467539
03/16/18 10:45 PM
03/16/18 10:45 PM
sgcuda Offline
sgcuda  Offline
Good to know that Diamond will help with custom orders like that. As I'm finding out, building a B1 engine is just slightly higher in price than building an Indy head setup. blush
Re: stroker kit [Re: sgcuda] #2467660
03/17/18 10:30 AM
03/17/18 10:30 AM
Finland
Hessu Offline
Hessu  Offline
Finland
Just buy rods and pistons from venolia. Great price and good lookin parts.
Re: stroker kit [Re: Hessu] #2469578
03/21/18 09:01 AM
03/21/18 09:01 AM
NY
NY
I decided to stay at 499 ci and ordered rods from manley and pistons from icon thanks for all the help Matt.
Re: stroker kit [Re: moparmatt0] #2469769
03/21/18 03:44 PM
03/21/18 03:44 PM
Carson City, Nevada
Carson City, Nevada
ICON knows all about B1 Heads, ask for Daniel. up
