Lexan #2467184
03/16/18 01:29 AM
03/16/18 01:29 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
Where are you guy's getting your 1/8" Lexan for side windows. Local glass shop is pretty proud of their stock $$$$$$$. Do you use clear or tinted?
Re: Lexan [Re: rowin4] #2467210
03/16/18 03:23 AM
03/16/18 03:23 AM
Check on line with Aircraft Spruce aircraft supply and or Chief Aircraft parts in Grants Pass, OR scope
I have bought the mar proof quality Lexan 1/8x4x8 ft. sheets years ago from a plastic supply whole seller in SO CA , I still have it most of left realcrazy
Re: Lexan [Re: rowin4] #2467358
03/16/18 03:15 PM
03/16/18 03:15 PM
rowin4 Offline OP
rowin4  Offline OP
I plan on doing just the door windows on my 70 'cuda so I won't need a 4 x x8 sheet.The local shop wanted $244. bucks for a 4 x 4 x 1/8" For that price I'll just leave in the old plexiglass at was in it when I bought it.
Re: Lexan [Re: rowin4] #2467361
03/16/18 03:20 PM
03/16/18 03:20 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Plastic supply and sign supply places handle it.
Re: Lexan [Re: rowin4] #2467369
03/16/18 03:41 PM
03/16/18 03:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
General Rubber and Plastic.
Lexan is a brand. Polycarbonate is the product you want. Get the scratch resistant coating.
