Re: ALI VS IRON Block
[Re: MattW]
#2467004
03/15/18 06:12 PM
03/15/18 06:12 PM
Posts: 11,705 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
These cars are still Stockers and have to meet the rules as far as allowed replacement parts, at least for NHRA. I haven't looked for accepted blocks for these cars, and I haven't looked at the NMCA rules so I don't know if they are allowed anything different.
[Re: MattW]
#2467018
03/15/18 06:42 PM
03/15/18 06:42 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
The NMCA uses NHRA rules for Stock/SS and shootout cars. Which is why Holley recognizes this as the first 7 second run by a shootout car. AS for the aluminum block I am sure it is all about the weight. They do have minimum weights but being able to put that weight were it is needed or will work best is likely the reasoning. Car was built by MR2 and I'm sure that's the thinking. The Air was KILLER when they made that run, like unheard of for Florida. Water grains below 20 the barometer was 30.+ and the DA was in the 500' area. Before the rains came Saturday
[Re: MattW]
#2467037
03/15/18 07:46 PM
03/15/18 07:46 PM
Posts: 10,019 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A friend, Chuck Lofgren, runs a 6.1 drag pak car and said the aluminum block makes a bunch more power. No doubt though the front end wieght change didn't hurt! He complained about huge wheel stands. Haven't seen the car run since the change though.
[Re: MattW]
#2467046
03/15/18 08:02 PM
03/15/18 08:02 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The air was crazy good. They were fast at Gainesville as well. I do see now where NHRA allowed the aluminum block to replace the iron block. I can't keep up.
[Re: MattW]
#2467149
03/15/18 11:58 PM
03/15/18 11:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Actually I read a story that said Mopar made the aluminum block a replacement part, accepted by NHRA, because all the iron blocks were only available as a long block assembly.
[Re: MattW]
#2467185
03/16/18 01:30 AM
03/16/18 01:30 AM
Posts: 20,212 Park Forest, IL
slantzilla
Park Forest, IL
They are package cars anyway. Ma Mopar (and the others) can pretty much get away with anything they want.
[Re: sgcuda]
#2467256
03/16/18 11:03 AM
03/16/18 11:03 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Maybe because Chevrolet engines are aluminum blocks. They may have had to make some considerations for Mopar. It's about time! Chevy blocks are iron...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2467258
03/16/18 11:10 AM
03/16/18 11:10 AM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Well Mopar should get a handicap because most of the guys on Moparts continue to argue that a cast iron block will produce so much more horsepower than an aluminum block will. Lol. Welcome to modern times guys.
[Re: CMcAllister]
#2467267
03/16/18 11:34 AM
03/16/18 11:34 AM
gregsdart
Actually I read a story that said Mopar made the aluminum block a replacement part, accepted by NHRA, because all the iron blocks were only available as a long block assembly. Much more likely it was as much or more ring seal as anything. If i recall correctly, Chuck said he picked up two tenths plus from that alone.
[Re: pittsburghracer]
#2467280
03/16/18 12:17 PM
03/16/18 12:17 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Well Mopar should get a handicap because most of the guys on Moparts continue to argue that a cast iron block will produce so much more horsepower than an aluminum block will. Lol. Welcome to modern times guys. At that level you need ALL your ducks in a row!! It's like top fuel, all have the power but it's who can put it to the ground. Matt
[Re: gregsdart]
#2467281
03/16/18 12:18 PM
03/16/18 12:18 PM
MattW
Ontario Canada
Actually I read a story that said Mopar made the aluminum block a replacement part, accepted by NHRA, because all the iron blocks were only available as a long block assembly. Much more likely it was as much or more ring seal as anything. If i recall correctly, Chuck said he picked up two tenths plus from that alone. I wonder if the 6.4 truck block would be better than the 6.1 in ring seal? Matt
#2467288
03/16/18 12:31 PM
03/16/18 12:31 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Well Mopar should get a handicap because most of the guys on Moparts continue to argue that a cast iron block will produce so much more horsepower than an aluminum block will. Lol. Welcome to modern times guys. I guess I'm one of the idiots that still believes an iron block can produce more power than aluminum.. I think that's been proven over and over.. but if you ask me what would be faster in the car.. that would be a whole nother question.. people need to consider weight and rules when picking a block.. if you have a car that weighs 2200 lb . And your class requirements require you to be 2800.. more than likely you would want an iron block.. if you have a car that weighs 3000.. and the rules say you can be 2800.. I would think you would want the aluminum block.. ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
