72 RR PS steering Shaft length? Charger different? #2465271
03/12/18 04:17 PM
03/12/18 04:17 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
I’ve parted 71-72 Chargers and a 72 Road Runner just came my way with a bad ignition switch and other issues.
I disassembled the column for service. I have parts from 2 Charger columns in boxes and used the cleanest stuff. Upon reinstall the shaft inow too short to mesh on the coupler.
I checked the break way pins and they are all in tact on all shafts.
I have 3 shafts.
A. 1 in the column, too short .
B. 1 same length and the
C. last is 1-2 “ longer.
I’m puzzled.
The columns parted were
71 Charger PS Floor shift
72 Charger PS column shift
72 RR PS floor shift
Thanks in advance
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465357
03/12/18 07:10 PM
03/12/18 07:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
It may look like they didn`t break but I bet the shaft has moved.
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465432
03/12/18 09:39 PM
03/12/18 09:39 PM
DC, MD Suburbs
DC, MD Suburbs
ill Check again
1972 Charger w 383
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465457
03/12/18 10:07 PM
03/12/18 10:07 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
There's a spec at the coupler...
Check the service manual...
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465501
03/12/18 10:45 PM
03/12/18 10:45 PM
DC, MD Suburbs
DC, MD Suburbs
The spec is the shaft adjustment once installed. 13/16”. When columns bolted in place the coupler on the column won’t reach the steering box.
1972 Charger w 383
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465527
03/12/18 11:14 PM
03/12/18 11:14 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Let me see if I understand, are you saying that when the shaft, and associated parts are in the coupler, and secured with the roll pin, and the hole in the shaft is 13/ 16ths from the coupler, that the column won't bolt up under the dash? Is that what you are saying? I have a reason for asking this.
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465656
03/13/18 09:38 AM
03/13/18 09:38 AM
DC, MD Suburbs
DC, MD Suburbs
Yes. I slid it through the firewall and had a helper hold the column in the car as O connected the coupler. Once the coupler was on the splines, I then raised the column to the dash mounting studs and it was too short that way to capture the studs.
I checked the column dash mount I used against the others in the box. No diffeeence and all 4 bolts are bolted to column jacket.
Then I tried to bolt column to dash and see how short it was. Coupler won’t reach the column spline even fully extended.
It prob something dumb and Im finishing a floor so I’ll do some more investigation after welding. Gonna reread FSM too
1972 Charger w 383
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465675
03/13/18 10:59 AM
03/13/18 10:59 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Install the coupler on the box first, by itself and install the roll pin, it makes the rest a lot easer. Was one of these columns installed in this car when you started? The reason I ask is I had the same troubles , and come to find out I had a 73/74 coupler.
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465681
03/13/18 11:38 AM
03/13/18 11:38 AM
DC, MD Suburbs
DC, MD Suburbs
Ok. I will compare couplers. Never had 73 up
1972 Charger w 383
Re: 72 RR PS steering Shaft length? Charger different? [Re: 440PURSUIT] #2465808
03/13/18 03:15 PM
03/13/18 03:15 PM
DC, MD Suburbs
DC, MD Suburbs
I think I used the column shift jacket with the floor shift shaft.
Some jackets have mesh and others don’t. Identifying now
1972 Charger w 383
