E 85 racers, how much compression are you running now?
#2465409
03/12/18 09:05 PM
03/12/18 09:05 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
I'm finishing up a new motor for my bracket car, it is a 400 stroker motor with a set of 440-1 heads that ended up with more mechanical compression than I had originally planned on What compression ratio are you guys running in your bracket cars now? Thanks in advance, your help is appreciated
Re: E 85 racers, how much compression are you running now?
[Re: Cab_Burge]
#2465413
03/12/18 09:17 PM
03/12/18 09:17 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Cab it wasn't that long ago we made 866.. on pumps junk on qmp's dyno.. that motor was around 13 to 1.. and made Power to 8200.. but was always kind of hard on the rod bearings.. I think E85 is the greatest thing since the invention of cheese.. but I think you're better off being on the safe side my opinion only
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Cab_Burge]
#2465445
03/12/18 09:53 PM
03/12/18 09:53 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
12 to 1 here. Alum headed smallblock
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2465447
03/12/18 09:56 PM
03/12/18 09:56 PM
dartman366
Mt. Vernon, Ohio
I was right at 13-1 with my smallblock when I was trying E-85.
[Re: Cab_Burge]
#2465648
03/13/18 08:36 AM
03/13/18 08:36 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Cab, if e98 is available locally, a brew with some race gas rather than pump swill might make a big difference. I have seen e98 for sale in nw Minnesota and it was much cheaper (according to a friend) than pump e85, and it was available in 55 gal drums. There would be no fed or state taxes on the e98. If e85 is made with 86 oct, then a mix of 110 race fuel to make e80 , or 20 percent race gas, might push octane to about 113 ? I am guessing on the facts hear, but using the math for mixing race fuels. If there are local ethenol alcohol plants in the area, that might be a source. Info might be available on an e85 race site.
[Re: Cab_Burge]
#2465760
03/13/18 01:56 PM
03/13/18 01:56 PM
Triple Threat
Renton Washington
My Hemi is 13.5:1 and the bearings look like new after 400 runs.
I have friends with big block chevies over 14:1 on pump E85.
[Re: Cab_Burge]
#2465768
03/13/18 02:12 PM
03/13/18 02:12 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
12.5 iron heads, big block.
Have a great day Iowan
"obsolete is neat"
[Re: Cab_Burge]
#2465848
03/13/18 04:22 PM
03/13/18 04:22 PM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
Wouldnt the Cam have something to add to the equation ?.
[Re: VernMotor]
#2466037
03/13/18 09:40 PM
03/13/18 09:40 PM
Cab_Burge
This motor has between 14.8 and 15.1 compression ratio checking all eight cylinders, the cam is 282@.050 intake(.457 lobe lift on both lobes, I'm using 1.61 ratio rockers) and 292@.050 on the exhaust ground on a 108 LSA installed at 103 to 105 ILC( I check the LSA at three different heights, .200, .100 and at .050 from max lift on both the intake and exhaust lobes What little info I could find on the internet forums on E85 and calling around to guys I know who race with E85 all basically say 15.0 to 1 is the max compression ratio to use with common pump E85 I am going to check locally to see if I can buy a 55 gallon drum of E98 and use it to help me adjust the local pump swill E85 to get around E90 to race with Hopefully I won't hurt this new rascal while learning to retune the tune up Thanks to all for the help
[Re: Cab_Burge]
#2466430
03/14/18 03:54 PM
03/14/18 03:54 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
I'm finishing up a new motor for my bracket car, it is a 400 stroker motor with a set of 440-1 heads that ended up with more mechanical compression than I had originally planned on What compression ratio are you guys running in your bracket cars now? Thanks in advance, your help is appreciated 12.8 and I test it before filling my drums. Cam timing will help. 493 ci is being freshened right now. Ray said everything looks good! Don
[Re: Cab_Burge]
#2466500
03/14/18 05:46 PM
03/14/18 05:46 PM
Posts: 4,210 New York
polyspheric
New York
The max effective ratio will vary with chamber shape, valve inclination, intake valve location, VE, etc. A small angle wedge with long stroke will tend to shroud the intake valve with a high CR, and also mask flame travel.
Boffin Emeritus
[Re: polyspheric]
#2466538
03/14/18 06:39 PM
03/14/18 06:39 PM
dogdays
Not arguing with Poly at all here, he cites a very specific case, but IN GENERAL:
Flame travel for a quiescent mixture in a gasoline engine is woefully slow. As the rpm and stroke length increase, the flame travel is even less than the piston speed! That's why squish is so very important, it mixes the flame through the chamber which speeds up the lighting off process. Because the flame travel is slow, larger diameters give longer time for the flame to travel and give more time for the mixtures out at the ends of the flame path time to form knock-prone compounds. As a result, with everything else being equal, larger diameter cylinders need more octane.
R.
[Re: Cab_Burge]
#2466547
03/14/18 06:53 PM
03/14/18 06:53 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
There are alternatives to pump E85. Torco, VP and I'm sure others sell their versions of E85. We picked up a solid 2 tenths switching from pump to VP. I know others with similar results at your compression ratio as well. Let me add that at the time finding DECENT E85 in Vegas was a challenge which prompted our switch to drums
[Re: Al_Alguire]
#2466732
03/15/18 01:27 AM
03/15/18 01:27 AM
Just-a-dart
Glendora Ca.
There are alternatives to pump E85. Torco, VP and I'm sure others sell their versions of E85. We picked up a solid 2 tenths switching from pump to VP. I know others with similar results at your compression ratio as well. Let me add that at the time finding DECENT E85 in Vegas was a challenge which prompted our switch to drums So what you are saying Al is when racing in Vegas I should bring my own alcohol?
